1912 Ford Front Hub Difference
Posted: Sun Oct 19, 2025 11:05 am
by J1MGOLDEN
Would anyone know the Factory Number for a 1912 Front Wheel Hub or know how to tell the difference from the earlier and later Front Hubs.
Re: 1912 Ford Front Hub Difference
Posted: Sun Oct 19, 2025 12:00 pm
by love2T's
J1MGOLDEN wrote: ↑Sun Oct 19, 2025 11:05 am
Well for one thing the later hubs have a wider "shoulder" I'll call it just inwards of the hub cap threads. Real early hubs were also smaller diameter I believe.
Posted: Sun Oct 19, 2025 12:05 pm
by love2T's
Well I had to look it up...factory number is 291 but its the same for the later hub with the wider shoulder.
I thought that shoulder started in '18 but it was in '17.
Posted: Sun Oct 19, 2025 1:22 pm
Rather than call the hub a 1912, why not call it an early front hub which was probably used through 1917? The outer part of the hub which holds the race is weaker than the later hubs, and that is why they were redesigned. I have taken later hubs, and had the thread area extended to look like an early hub with no problems. You don't even have to move the threads back further either, because there is enough of the existing threads to hold the hubcap on. This way you can still use the taper roller bearings.
Posted: Sun Oct 19, 2025 1:32 pm
by J1MGOLDEN
219 is the Factory Number for the 1909 to 1927 replacement hubs.
If you are doing an exact 1912 restoration, the 1912 hub is required.
They are not all the same and Gail missed the different 1912 hub.
Posted: Sun Oct 19, 2025 7:00 pm
by Chris Instness
Here is an old thread discussing front hub changes that may be helpful.
https://www.mtfca.com/discus/messages/8 ... 1239905425
