Ruckstell Shift Rod Relocation
Posted: Sat Jul 06, 2019 6:21 pm
				I'm putting the Sure Stop Disc Brake kit on my '25 Touring and so I have to flip the Ruckstell shift rod connection from the left (driver) side of the transmission to the right (passenger) side.
After about an hour of fooling around with it I have come to the conclusion that I'm going to have to bend the shifting rod to make it fit, but before I do that I wanted to check here to make sure I'm not overlooking something obvious.
I have the one piece shift rod and the shift rod support is loose on the driveshaft tube as I'm manipulating it.
Is it common to have to bend the rod when doing this kind of relocation?
Any advice would be appreciated.
Thanks!
Thanks!
