Firewall Brass Trim (Flat)
Posted: Fri Nov 14, 2025 12:02 pm
by BRENT in 10-uh-C
Is anyone still making, (-or does anyone sell) the flat brass Firewall Trim like was used on the edge of 1914 Firewalls??
TIA
Re: Firewall Brass Trim (Flat)
Posted: Fri Nov 14, 2025 12:18 pm
by t-time
Try Restoration Supply Co in Escondido Ca
Posted: Fri Nov 14, 2025 12:45 pm
by Rich P. Bingham
The 1913-14 brass trim is a “U” configuration. Be sure you get the right trim. For over 50 years these cars have been fitted with reproduction dash boards made of 3/4” cabinet plywood. The original solid laminated dash boards measured 13/16” thick. I hope they are available in both sizes, I had difficulty finding it when I replaced the dash in my ‘13.
Posted: Fri Nov 14, 2025 1:59 pm
by RGould1910
I don't know. The slight overhang didn't bother me. If it did, I'd veneer the plywood.
Posted: Fri Nov 14, 2025 2:47 pm
Lang's has that flat trim.
Might call to see if this flat has the 1/4" overhang, on both sides, isn't clear in the description or photo.
Did get some oval trim from Restoration Supply to put on the faux '12 firewall. Has lips on both sides to hide the wood edges of the firewall.
Posted: Fri Nov 14, 2025 4:39 pm
To me, a 13-14 is a sort of a U, but flat on the top and sides. The sides have a very slight U configuration on the edges.
Posted: Fri Nov 14, 2025 5:36 pm
by Henry K. Lee
Larry is correct..., the rounded trim is actual for boats. I have to make it on a sheet metal brake in the past or use a power roller with 3/4" flat dies..., works either way.
Just Sayin
Posted: Sat Nov 15, 2025 12:18 pm
by BRENT in 10-uh-C
Henry K. Lee wrote: ↑Fri Nov 14, 2025 5:36 pm
Just Sayin
Thank you Sir. I have definitely considered either making it on my Pullmax by making a set of dies out of Delrin. I have even thought about using the same dies to flatten the Oval moulding however I have not been able to locate anyone who is stocking it. So what grade Brass did you use and who was your supplier??
Posted: Sat Nov 15, 2025 3:53 pm
by Henry K. Lee
Online metals has whatever you need. They give you options in grades.
Posted: Sat Nov 15, 2025 5:43 pm
by George House
Henry Lee said “The rounded trim is actually for boats.”
Not so fast Hank. Here is an example of quite a bit of rounded trim I acquired off a salvaged 1910-1911 REO.
Posted: Sat Nov 15, 2025 5:47 pm
by Henry K. Lee
REO yes....., Ford no. You must anneal the rounded brass or you will kink it. You think Henry Ford would have added extra steps in that? Flat can be slapped with a mallet with a light edge support.
