Timing mark
Posted: Fri Nov 28, 2025 4:36 pm
by big2bird
Has anyone ever set up a pointer/ mark on a T motor for TDC? Just asking, since I use a Bosch front plate.
Re: Timing mark
Posted: Fri Nov 28, 2025 5:26 pm
by DHort
It has been done at the Speedster Reunion to get dynometer readings, so it should work for you.
Re: Timing mark
Posted: Sat Nov 29, 2025 1:09 am
by Dodge
I just use a fine line paint pin and put a mark on the back of the pulley and the timing cover.
Re: Timing mark
Posted: Sat Nov 29, 2025 10:05 am
by AndyClary
If you have an aluminum pulley you can use the split for a timing mark. On stock pulleys on run the paint marks around the back a little away from the belt.
Andy
Re: Timing mark
Posted: Sat Nov 29, 2025 10:50 am
by Jerry VanOoteghem
AndyClary wrote: ↑Sat Nov 29, 2025 10:05 am
Andy
True! And very handy. Just be sure when you install the pulley to align the split with #1 TDC and not BDC, (bottom-dead-center).
