Driveshaft advice
Posted: Tue Jul 09, 2019 8:28 pm
I just finished rebuilding my driveshaft and rear axle on my 1910 and test fit the entire assembly. I installed everything in both the axle housings and the driveshaft and bolted all together including the rear radius arms. I wanted to be sure there were no snags before applying grease and gasket sealer so I left that off. Everything seems to fit the way it should and the only issue (maybe) is that the U-joint stub seems a bit difficult to turn by hand; in fact, the only way it does turn is with the help of a wrench on the end of the stub. It's not binding and it really isn't that hard to turn with the wrench but is it supposed to turn by hand? Maybe after I take it all apart and apply grease and lubricant it will turn easier.
