Himico manifold install
Posted: Tue Jul 09, 2019 9:49 pm
by csnailnrun
Who is running a Himico manifold that can share if there is special install hardware? Fine thread hex bolts seem to be ok but the outer portions of the manifold is a similar dimple of a standard manifold. Maybe too innermost where the intake comes up. Any advice?
Re: Himico manifold install
Posted: Tue Jul 09, 2019 10:28 pm
by Ruxstel24
I had a Wilmo, kinda sorta like that.
It used the studs and straps like a stock setup.
That's the only way to get pressure on the center ports. Just standard rings/glands.
I actually have/had bolts...
Posted: Wed Jul 10, 2019 8:30 pm
by csnailnrun
Standard clamps do not work for this manifold.
Any other suggestions?
Posted: Thu Jul 11, 2019 10:33 am
by Mark Gregush
If the area where the stud comes thru on both sides is the same height;
The Model A used an extra thick washer in this area. They are concave on one side so only the edge put pressure on the mounting. The only problem I could see using those is the Model A stud is 7/16 and the T 3/8. The hole would be a little big but might work.
https://www.snydersantiqueauto.com/Prod ... hByKeyword
Posted: Thu Jul 11, 2019 11:14 am
by csnailnrun
Great tip Mark!
