I understand that instead of a wooden block between the front fender and running board there was two "spacers". Were these essentially thick washers? And how thick were they?
1924 fender to running board question
Topic author - Posts: 82
- First Name: Charles
- Last Name: Little
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1924 Del. Truck, 1924 Touring
- MTFCA Number: 24280
- MTFCI Number: 17733
Charlie Little, South Paris, Maine
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: 1924 fender to running board question
Yes the earlier fenders had a washer between the fender and the running board. In '25 the fenders were modified to have a raised area around the bolt holes, eliminating the need for the washer. R. V. Anderson makes a bolt kit for the fenders & running boards that has the correct washer included.
- MTFCA Number: 121
- MTFCI Number: 16310
Just use a relatively thick 5/16" washer about the same diameter as a quarter.
