Clutch lever adjusting bolt
Topic author - Posts: 85
- First Name: Preston
- Last Name: Wells
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
- Board Member Since: 2008
Can someone provide the dimentions and TPI of the clutch lever adjusting bolt.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Clutch lever adjusting bolt
p/n 3403 is 3/8" - 24tpi x 1 5/16". Can also use Fan adj. screw, p/n3973.
Like to turn the bolt head upside down, and grind the hex a bit rounded as that make a wider surface for contact on the controller shaft. Add some grease too.
- Last Name: Wells
Perfect, thanks Dan
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
