Ammeter does not register a charge
Posted: Mon Jul 15, 2019 1:49 pm
Hello all,
I see another thread just started about a generator not charging. I've started my own so not to piggyback .
My generator appears to be charging, although it is registering the same voltage reading as the battery side on the cutout. The reading is slightly above 6 volts.
With engine NOT running the battery side of cutout reads slightly above 6 volts with NO reading on generator side.
Ammeter does not register a charge when I raise engine speed. The ammeter does register a discharge when I turn lights on. Shouldn't the generator output reading be higher than 6 volts? And like I've said I'm using a cutout on the generator, however, I have a Fun Projects voltage regulator that I want to install but not until I am confident the charging system is performing proper.
