What Transmission Is This Bracket For?
Topic author - Posts: 2293
- Last Name: House
- MTFCA Number: 115
...All I know is that it’s not Ruckstell. Anybody know? It matches the forward end collar of the T torque tube...
I don’t know why I turned out this way. My parents were decent people.
- Last Name: House
- MTFCA Number: 115
Re: What Transmission Is This Bracket For?
**btt**
- MTFCA Number: 14972
- MTFCI Number: 15411
The early Hall-Scott shifter mount for the TT truck was similar - mounts to the 2 right side ball cap bolts, top & bottom - not the top 2.
- Last Name: House
- MTFCA Number: 115
Thanks Steve...now, does anybody have a need for it ??
I worked on a T buckboard with a Ruckstel that had two of those brackets, one on each side of the ball housing. The standard Ruckstel shifter was mounted between them.
- MTFCA Number: 121
- MTFCI Number: 16310
Doesn't look like anything Ruckstell ever made to me! I don't even think the two holes line up with the ball cap.
- Last Name: Morsher
George, if it matches the ball cap holes, I’d be interested in it. I’m still working something up for my jumbo planatar. Tmorsher@icloud.com if you want to discuss.
- Last Name: House
- MTFCA Number: 115
Well, you think wrong Original..Now I’ll contact Tim...george
- First Name: Bruce
- Last Name: Csorba
- * REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Here is the complete set up.
It was operating the ruckstell in our 25. (Similar to what Allan saw)
It has LH and RH cast into each side and part Nos 2056 and 2057 stamped in.
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
- Last Name: House
- MTFCA Number: 115
Most interesting Bruce ! You’ve enlightened all of us. Many thanks !!
That's the one Bruce. At the time I was working on the buckboard, I was pondering whether the lever could be mounted to the left or right by switching it in the mounting brackets. I think it is possible, but wonder if there is any advantage.
I believe that due to the TT having the battery box next to the running board, the shift rod going rearward goes straight back whereas on the passenger car equipped w/electric starting equipment with the factory battery holder, the shift lever goes to the passenger side to cross over the torque tube in order to miss the battery.
