KW Coil Box Id
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- MTFCA Number: 49671
KW Coil Box Id
The KW coil box pictured was found in the back seat of a 1913 Ford Touring. The box shows traces of red paint on the front.
It does not appear to be repainted.
All the boxes I’ve seen have black and gold graphics.
Can someone identify the year of the KW box pictured?
Thank you,
Gene
Thank you,
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: KW Coil Box Id
1913, I believe.
- First Name: Gene
Re: KW Coil Box Id
Steve,
Do you believe that the traces of red paint are original to the box?
In my very limited experience, I've not seen a KW with red graphics.
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Re: KW Coil Box Id
Gene,
Here is a complete discussion around the K-W Coils and box
http://www.mtfca.com/coils/Coils.htm
Regards,
Re: KW Coil Box Id
I cannot verify what was the original color scheme on those switches but I do have a switch cover with red color in it's composition - not sure if it's a NOS or very old reproduction - only red one I've seen. I'll get a photo tomorrow.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: KW Coil Box Id
Here’s one I bought at a swap meet 2 weeks ago. Pretty nice original condition and painted black. Too bad it doesn’t have a lid...
- First Name: Adam
- MTFCI Number: 1
Re: KW Coil Box Id
Forgot to mention; I posted this to show the seemingly original black paint (not stained & varnished). The brass switch plate is likely a replacement.
- MTFCA Number: 121
- MTFCI Number: 16310
Re: KW Coil Box Id
A side view of that box would nail it! The red paint on the switch place was done at a later date. The only paint on the switch plate when new was in the KW circle. Your coil box has been revarnished at some point. They were originally the same color as the firewall.
- MTFCA Number: 121
Re: KW Coil Box Id
Adam:
If you will look at the top edge of your coilbox, there are traces of the original red stain. You are fortunate to have that box. Randall Andersons brother Jon can make you a new lid. I've discovered not all 1913 KW lids are interchangeable! I've probably owned a half dozen 1913 KW coil boxes over the years.
