Line boring early block
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Sat Aug 03, 2019 8:20 pm
One of today’s projects. Main bearings on a 1909 block.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Line boring early block
Post by Henry K. Lee » Sat Aug 03, 2019 8:34 pm
That's an early Puppy Erik!'
modeltbarn
First Name: Gary
Last Name: London
MTFCA Number: 16592
Post by modeltbarn » Sat Aug 03, 2019 11:26 pm
Is that Mike's?
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Sun Aug 04, 2019 3:10 am
Yes it is an early one. Number is just over 5000. I know the owner as as Micheal.
John Warren
Last Name: Warren
Post by John Warren » Sun Aug 04, 2019 8:25 am
Thanks for sharing Eric. Always great to hear from you.
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Sun Aug 04, 2019 10:01 am
Interesting picture, Erik. I've never actually seen a line boring operation, so maybe this is a dumb question (won't be my first ........ or last).
I notice that the block is not clamped down to the table. As a matter of fact, it appears to be sitting on a cushion of shop rags. So, what keeps the block aligned to the machine's drive during the boring operation ?
Thank you,
Dick
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1912 Warren Speedster
MTFCA Number: 50392
Post by NorthSouth » Tue Aug 06, 2019 9:54 pm
If I remember my lessons from Rumble Seat Garage, the above photographs show only the first stage of a finely tuned two jig boring process.
KimDobbins
First Name: Kim
Last Name: Dobbins
* REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
MTFCA Number: 8243
Post by KimDobbins » Tue Aug 06, 2019 10:44 pm
Erik, if you lay a standard crank in the bearing surfaces, how much wear if there? Or was the block previously babbited?
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Wed Aug 07, 2019 11:30 am
The block is clamped down through the cylinder bores. The rags are there to protect the deck surface from scratching. The mill drives the bar with a flexible coupling so perfect alignment is not required, but I get it close. This block has been opened up to use babbit on the upper main bearings. Originally it would have run the crank in the iron bores.
