Babbitt Material
keen25
First Name: Eric
Last Name: Keenan
* REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
Babbitt Material
Post by keen25 » Tue Aug 06, 2019 6:58 pm
Where is the best place to buy Babbitt material? Who has the formula that is the best grade or one that is the same composition as the Ford model T? Thank you. Erick
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: Babbitt Material
Post by Erik Barrett » Tue Aug 06, 2019 7:57 pm
I buy government grade #2 from United Metals. They publish their formulae online and it is what Ford used for model T’s.
Kerry
Last Name: van Ekeren
Post by Kerry » Tue Aug 06, 2019 8:15 pm
If your only doing 1 engine then buy the babbitt from the T vendors. I don't know about your area but down my way if you want babbitt from a metal merchant supplier you can only buy in bulk, which is fine if doing several engines.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Tue Aug 06, 2019 8:21 pm
Not the same as Fords, Erik.
Herm.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue Aug 06, 2019 9:15 pm
Here a place that makes Ford babbitt. http://stores.acrosales.com/fordbabbitt/
Dan
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
MTFCA Number: 50306
Post by modernbeat » Wed Aug 07, 2019 8:04 am
While there is debate about what is the "best" Babbitt, there are a number of similar materials to what Ford specified.
You can buy smaller quantities here:
https://www.kappalloy.com/babbitt-alloy ... urakapp-2/
https://www.kappalloy.com/kappatinningt ... -1-lb-jar/
Jason McDaniel
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Wed Aug 07, 2019 11:24 am
Herm, please elaborate. I’d like to learn more.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Wed Aug 07, 2019 3:46 pm
I will try to do it tonight, Mr. Erik, I am pouring in a 1903 Olds, today.
Herm.
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Aug 07, 2019 4:11 pm
Here it is !
[attachment=0]
Kerry
Post by Kerry » Wed Aug 07, 2019 5:24 pm
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Wed Aug 07, 2019 9:47 pm
Just because babbitt has Ford in the babbitt, does not mean it came from the Ford Factory, it may be 86-7-7, but it didn't come from Ford.
The babbitt in the Ford Garages, that we got with Wilson tools, that was Ford Babbitt, all had Ford Imprinted in the bar, and written out, Just like the Model T, and A, signs.
We have had a lot of Babbitt that was Printed Ford in it, but was lead Babbitt. Henrys, Gyp parts.
Most all Bearing Manufacturers, used Grade No. 11, specified by car builders.
We use Grade No. 11, and also a lot of Grade No. 2.
We don't use much of 86-7-7, Ford formula, as it machines dirty.
Herm.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Wed Aug 07, 2019 10:28 pm
Just in case anyone in Australia stumbles across this thread, I use Consolidated Alloys "Auto" white metal.
http://www.cagroup.com.au/wp-content/up ... s-2017.pdf
You can buy it direct from them or order it through a reseller like Blackwoods or Bunnings Trade.
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Aug 07, 2019 10:34 pm
BUT IT SAYS “GENUINE “. Thought I’d go fishing with that pic and I caught a big one !
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Thu Aug 08, 2019 1:19 am
Herm, thanks for the input. I will stick with grade 2. My book on rebuilding model A’s claims that Ford went to a cheaper lead base babbit because they thought the more robust, larger crankshaft did not require the more expensive grade. Maybe that is why the Ford name is on some lower grade babbit ingots? Just a thought. Is your Oldsmobile project a curved dash one cylinder? Always an admirer of your work and formidable experience. The oldest thing I have done bearing work on is a 1904 B Ford.
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Fri Aug 09, 2019 2:09 am
Herm, how do you chose when you use Grade No. 11 and when you use Grade No. 2 Babbitt?
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Fri Aug 09, 2019 9:49 pm
Grade 2 is fine, we use it some times. Buddy, it all depends on price, and availability.
Yes, that was in, I think early V-8's. The Early Ford V-8 Forum would know.
Yes, Ford tried Lead, a Copper Lead, it didn't work out, so they went to a Cadmium Sliver alloy.
The V-8 Ford Ron Bearings were never repoured, as they wear on out side, and in.
The olds is a Curved Dash, 1903. we have don a Shott " SP " A Yale, and I can't think of the other.
Herm.
