ignition switch
Posted: Thu Aug 08, 2019 8:24 pm
Is there somewhere that explains how the switch works?
I have a 26 , external DU4mag where generator was. Bought a switch to terminal harness. Using a couple of wiring diagrams (Ron Patterson, Texas T), I have power with switch lever at DIM to headlights and tail lights, On to headlights (bright?) and tail lights. Terminal 3 is hot all the time, as is 1, regardless of the key. key turned to BAT gives me power to Coil, which I don't need anymore. Key turned to MAG. no power at terminal.
With the external magneto, can I use the switch to run the lights, or do I just use the battery? Using a fuel pump, what terminal do I use so it's on only when engine is running?
Also, if I was factory original, where would the key be turned at starting? If the spark from the magneto post goes to the switch, it then goes to the coil? should the key be at MAG? Why do I have power to coil at BAT? Sorry to be so dense.
