RHD Engine Questions
Posted: Mon Aug 12, 2019 3:00 pm
by Jeepbone1
Can someone who has built up a RHD engine give me a call/text or email please? I have a few questions.
Brad
540761230three
Bkirtner@gmail.com
Re: RHD Engine Questions
Posted: Mon Aug 12, 2019 6:44 pm
by Kerry
Brad, as for your post in saying the engine, there is no difference from LHD/RHD. just the transmission hogs head and the throttle shaft in the carby.
Posted: Mon Aug 12, 2019 7:45 pm
by John E. Guitar
Can you post your questions on the forum?
I've got an engine sitting on a stand I can take photos of if that would help.
Posted: Mon Aug 12, 2019 8:23 pm
by ModelT46
65 years ago I turned a 1909 roadster into a right hand drive. I changed a steering column into a right hand , used a right hand timer, a right hand trans cover, changed the lever to a right hand and other small items. Not much trouble at all. The car went to California. I wondered where it is now.
Posted: Tue Aug 13, 2019 6:43 pm
by nsbrassnut
Hi All
Well I just had to chime in on this one having recently got a Canadian RHD car back on the road.
Yes you can modify part for the conversion, but the list of parts that are different does add up. For example here is a list of most of the parts that are specific to the RHD cars that you need to remember.
Some of the differences between LHD and RHD Model T Fords.
- Carburetor throttle lever (90 degree different movement) and so a different arm on the carburetor
- Spark and throttle rods (throttle is on the right, throttle on the left) and their connecting levers (the throttle and spark linkage ones) are also RHD specific
- Timer, actuator rod connects at the bottom of the timer, oiler at the top (regular one turned upside down will work)
- Timer and throttle control rods require one swivel per rod to get the movement to work correctly. With the swivel its a simple linkage, without gets awkward.
- Steering drag link from the steering arm to the tie rod (twist is 90 degrees in the other direction)
- Steering bracket at the frame mount, RHD specific
- Tie rod, the ball is on the left side not the right but the ends are still the same way up and not easily changed from LHD ones
- Emergency brake lever and emergency brake cross shaft
- Some of the differences between LHD and RHD Model T Fords.
- Timer, actuator rod connects at the bottom of the time, oiler at the top (regular one turned upside down will work)
- Emergency brake ratchet quadrant for frame
- Tail light bracket (oil lights with license plate mount) the license plate arm is on the left because the bracket mounts on the right side of the body
There is actually a fair number of differences between the two models and you will need to collect several additional bits if you want to assemble a good working RHD T.
Have fun with the project.
Jeff
Nova Scotia Canada
Posted: Tue Aug 13, 2019 8:33 pm
by Allan
Jeff's list is about as comprehensive as you can get. While the two rods connecting the carburetor and timer work well with a swivel joint, they were not always used. Most of our Canadian sourced cars during the 20's just had the ends of the rods bent and pinned.
Getting the exhaust pipe around the pedals, and past the foot starter switch will also be a challenge. It requires quite some different bends over a LHD unit.
Posted: Tue Aug 13, 2019 9:44 pm
by Mark Gregush
If the pedal shafts need to be replaced, they are different also
