Penny shims
Topic author - Posts: 6496
- MTFCA Number: 16175
- MTFCI Number: 14758
Penny shims
They're a temporary measure at best. This was a pre-82 cent, but that didn't keep it from wearing out in just a few years.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: Penny shims
Luckily, they're cheap!
Re: Penny shims
Are you sure that was a pre-'82? The way it squished looks more like the zinc cents. I have seen several from parking lots after being run over by cars a few hundred times. They seem to be a graduated sort of zinc/copper alloy and reveal more zinc from the center layers when they get beaten out. Yours in the picture looks that way.
Just wondering.
Just wondering.
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Penny shims
Mine seems to "self lubricate" said area. Savin my pennies...
Re: Penny shims
Yes, I made sure when I put it in. But it's squashed thinner than the pennies we used to put on the street car tracks.
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
- MTFCA Number: 16688
- MTFCI Number: 19356
Re: Penny shims
I weigh pennies as they pass through my possession and I've accumulated a roll of the heavy ones. U think they are worth $1.00 each as shims?
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: Penny shims
Shim for?
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
- MTFCA Number: 30697
Re: Penny shims
I will sell you some shims for a buck
- First Name: gary
- Last Name: hammond
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster
Re: Penny shims
The later copper-clad aluminum pennies cost us the taxpayers 3 cents each to produce.....
''Just Passin' Thru.....Slowly!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Penny shims
Use Canadian pennies, they stopped using them.
Re: Penny shims
The later copper-clad aluminum pennies...
The 1982+ cents are copper-plated zinc. CBS News reports that the cost of production last year was 1½¢ each. Cost varies year to year depending on the fluctuating cost of metals. In spite of its cost the US cent is unlikely to disappear anytime soon, because of the public's love for Abraham Lincoln and fondness for the coin that bears his likeness.
- First Name: Donald
- Last Name: Goodwin
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Re: Penny shims
what part was being shimmed? I am still learning.
- Last Name: Hanlon
Re: Penny shims
The "wishbone" ball socket.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Penny shims
Too small for the wishbone - fits the drag link.
- Last Name: Morsher
Re: Penny shims
Don, sadly, as often the case, “penny-wise and pound foolish “ REALLY applies here. For the purist, get good caps and rebuild your ball to round. Otherwise, actual era shims are readily available, and I’ll send you some if need be. These are for drag link ends and wishbone ball socket. They made aftermarket spring loaded accessories, which are the bees knees. Shown to upper right is the wishbone sized one. They are both available from parts suppliers, they may be made of brass or bronze, but I think Friend Dave has some originals over in Norton. He’ll fix you up.
Re: Penny shims
AND, if you are smart, put a small zerk or pin alemite fitting on it, and they will always be greased ! Just don’t let larry Smith see it.
Re: Penny shims
Don, this another period fix. These, though, belong in a display cabinet . I’m sure there are some thrifty T owners that use them, and they are neat to see on farmyard type restorations. You will likely see grooves on original parts that are very worn out, this is what made the grooves. These were used to stop rattles on those metal-to-metal wear points that this thread is discussing.
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Penny shims
Ever heard of filing the caps, and then packing them with wheel bearing grease?
Re: Penny shims
Sounds sort of familiar.
Re: Penny shims
Larry, filing the caps will do nothing for an out of round ball, just make it wear out faster. Do you have some magical grease that will take up the void?
Re: Penny shims
Thank you Tim for the information. I was curious as to where these were used. Like you said, it is wiser to rebuild the part instead of a patch.
Thanks again
Don
Thanks again
Don
