oil seal
Philip
First Name: Philip
Last Name: Thompson
oil seal
Post by Philip » Sat Aug 17, 2019 7:50 pm
Tried to do the glue on oil seal trick on a fellow
Club members car. I got the seal from langs
Split it every 1\4 inch or so flattened it out
And put it on backwards but it is too thick to allow the pulley to go on. Is there a thinner
Seal. Philip
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: oil seal
Post by Adam » Sun Aug 18, 2019 2:16 pm
The seal from Langs is supposed to go in the recess instead of the felt, not on the outside of the front.
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Re: oil seal
Post by SurfCityGene » Sun Aug 18, 2019 2:27 pm
How much clearance do you have? Yes, some of the seals are a bit thicker in construction than others and some cars have more clearance.
I just measured the SEAL thickness on one I have used and it is 0.210"! That's pretty thin and should be OK unless your pulley or crank is a bit different. This is a CR12458 sel.
Hope that helps.
1912 Torpedo Roadster
MTFCA Number: 14972
MTFCI Number: 15411
Re: oil seal
Post by RajoRacer » Sun Aug 18, 2019 2:28 pm
I believe he's referring to the crankshaft seal - not cam seal.
MTFCA Number: 14972
MTFCI Number: 15411
Re: oil seal
Post by RajoRacer » Sun Aug 18, 2019 2:29 pm
My mistake !
SurfCityGene
First Name: Gene
MTFCA Number: 22905
MTFCI Number: 23068
Re: oil seal
Post by SurfCityGene » Mon Aug 19, 2019 7:57 pm
Philip, Did you ever get this info about your crank seal that you requested??
