Wire spool source
Dellpound
First Name: Dell
Last Name: Pound
MTFCA Number: 17469
Wire spool source
Post by Dellpound » Wed Aug 21, 2019 11:22 am
Does anyone know a good source for small spools of cloth covered automotive wire? I prefer to buy spools instead of set lengths.
Re: Wire spool source
Post by Scott_Conger » Wed Aug 21, 2019 11:38 am
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Wed Aug 21, 2019 11:42 am
Check out Sacramento Vintage Ford. They sell vintage cloth covered wire.
https://www.vintageford.com/sect_vehicl ... ing%20Shop
916-853-2244
Post by Allan » Wed Aug 21, 2019 6:52 pm
I bought 6 different colour spools from these folk; www.ynzyesterdaysparts.com.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Aug 21, 2019 9:38 pm
Y n Z's yesterdays parts in Redlands, California. It's on Stewart Street. They will also make you an authentic custom loom from your original pattern. Gene, the owner, even wove the original Ford script tag into my looms for my 1925.
Post by Wayne Sheldon » Wed Aug 21, 2019 10:11 pm
Just be sure you get a heavy enough gauge wire! Six volt systems should not use 14 gauge. twelve gauge or even ten sometimes.
Sparknwire
First Name: RJ
Last Name: Lucyszyn
Post by Sparknwire » Thu Aug 22, 2019 12:47 pm
14 ga is mainly used on the harness generators 10-12ga
Dellpound
First Name: Dell
Last Name: Pound
MTFCA Number: 17469
Post by Dellpound » Fri Aug 23, 2019 1:06 pm
I thank those who responded. My supplies are on there way from numerous suppliers.
GalebG2
First Name: Oliver
Last Name: Vandebroucke
Post by GalebG2 » Sat Aug 24, 2019 12:01 pm
Thanks for the links, I'm not looking for wire spool for a Ford T, but I've found LOTS of other things I need on these shops...
