Wierd exhaust manifold Ford or what??
Topic author - Posts: 1656
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
looks close to Model T but never seen one like this could it be Metz or star ?? any ideas, Bob
thank you forum
thank you forum
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
- MTFCI Number: 13377
Re: Wierd exhaust manifold Ford or what??
Just the exhaust manifold from a vaporizer carb assembly . Common for 1927 Model T Ford
not vaporizer no opening in back, Bob
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
I believe its for a Simmons vaporizer.
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
there is no opening's in the back it is all solid , strange
- MTFCA Number: 52564
I was going to suggest Simmons but does not match ether;
http://www.mtfca.com/discus/messages/411944/416013.html
1920 Dodge touring
1920 Dodge touring
Only one small hole on top no vaporizer plate see photo's
- MTFCA Number: 16175
- MTFCI Number: 14758
Bob is right, of course. Ford part numbers begin at 2500. The Ford part number for a Vaporizer manifold is 6272, and the factory number is 4483C. It's not a Model T Ford part.
- First Name: Jim
- Last Name: Sims
After market manifold to fit Model T Ford. Most likely works similar to a vaporizer.
- MTFCA Number: 4838
- MTFCI Number: 115
As Jim noted, could be this one.....there were so many different aftermarket vaporizers offered.
