Cleaning old grease in black top
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Aug 24, 2019 7:16 pm
I’d like to clean some of the old established oil / grease droppings on my paved black top drive way. Has anyone tried enzymes like those used in drains?
Re: Cleaning old grease in black top
Post by Scott_Conger » Sat Aug 24, 2019 7:36 pm
I'm thinking out of the box here: how about a long-nap roller and 5 gallons of oil? An even look on the driveway, and spots will never show again :D
NH Full Flow Float Valves
Post by TRDxB2 » Sat Aug 24, 2019 7:54 pm
Blacktop is a mix of asphalt, sand and gravel. Asphalt is a petroleum product. Question is if you used a sealer o top of the blactop that wasn't another petroleum product. problem is , in removing the oil stain you may remove some asphalt. You could try scrubbing with Dawn dish-washing liquid / water mix or oil-dry. There are both latex & petroleum sealers - talked to you local home improvement store to see what you can use.
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
MTFCA Number: 30353
MTFCI Number: 23493
Post by Greg Griffin » Tue Aug 27, 2019 12:37 am
Hi Mark--
I haven't used this product, but I've used their concrete cleaner and it's worth the money.
store.actcleaners.com/asphalt-cleaner
If that doesn't work then just go to actcleaners.com and look around.
Greg
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Tue Aug 27, 2019 12:58 am
Tide and a scrub brush works well.
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Tue Aug 27, 2019 8:31 pm
I would try a 3 step process.
1) Put an ample layer of either SPEEDY DRY or CAT LITTER, 1 inch thick, on the spot you wish to clear.
2) With work boots, shoes, or sneakers, vigorously grind in the material into the spot with your foot until granules have become dust. I have a special 8 inch 2x4 block I use under foot instead of using the sole of one's shoes.
3) Sweep away dust and inspect target area. Repeat as necessary. Then sweep away all material, put down some dish soap, and work it into the spot with your shoe. Let sit for a half hour and rinse with a hose.
stain will barely be noticeable.
"Try it...... you'll like it!" 👍😁👌
________________
**FATE**
PM me if you have any Indian Motocycle parts!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Tue Aug 27, 2019 9:42 pm
Sure I’ve tried kitty litter several times. Doesn’t do much except become impossible to clean once it gets wet. This is old and hard not fresh oil.
