Nails for ignitions coils
Posted: Fri Aug 30, 2019 11:54 am
by keen25
Is there a supplier for the 2 small nails used in the Ignition coil to hold the cover on?
thank you, Erick
Re: Nails for ignitions coils
Posted: Fri Aug 30, 2019 12:13 pm
You should be able to find the wire brads at a good hardware store. Personally, I staple the door in place. Makes it easier to get into later if needed.
Posted: Fri Aug 30, 2019 4:29 pm
The 1914 and earlier KW coils use brads. I don't know about the other brands. Check with RV, he knows for sure.
