On...or...Off ???
Posted: Tue Sep 03, 2019 4:55 pm
by George Mills
I’m a guy who only has use of one leg....so working on de-gunking dirty fuel system has driven me nuts and taken months since I can only get down and under 2 times and can’t use a creeper and then spend 2 days recovering...lol
To save my mind and a trip under....is this Open or Closed ? I’m having a brain-spasm today
Re: On...or...Off ???
Posted: Tue Sep 03, 2019 5:03 pm
George
it's "on"
Posted: Tue Sep 03, 2019 5:11 pm
by George Mills
Thanks Scott,
This things driving me nuts...but I’ll prevail...eventually.
Move back! Lol
Posted: Tue Sep 03, 2019 10:56 pm
by Moxie26
George:
Are you riding out the storm in Florida, or elsewhere ??????? PM me as you wish.
Bob J.
Posted: Wed Sep 04, 2019 5:19 am
by bobt
I put a SMALL pinpoint of green paint on the handle and another on the fuel line so when they line up, It's "on" Works for me. Bobt
Posted: Wed Sep 04, 2019 8:28 am
by George Mills
Bob T great idea! I’ll take that...
Bob J we are over on the Gulf coast so spared this time once the errant spaghetti models decided to join the rest from Sunday on...
Posted: Wed Sep 04, 2019 10:48 am
If the handle lines up with the gas line, it's on.
Posted: Wed Sep 04, 2019 10:59 am
by Quickm007
Its on and when the pinion line up the gas line or if the pinion pointed the carb is off. Hope that help! I have the same pinion wich is original.
Posted: Wed Sep 04, 2019 11:06 am
Those who posted are very likely correct, but a positive proof, if the engine will run would be to turn the valve in the direction toward the carburetor and run until it runs out of gas. If that doesn't happen within a few minutes, try the valve in the other direction and you will know for sure. Problem with having the valve at that location, it will work for parking to keep from draining the tank, but you will still need to crawl under to turn it off if you want to remove the carburetor.
Posted: Wed Sep 04, 2019 12:32 pm
by NHUSA
That used to confuse me also.
Finally I drew a picture on the garage wall so I didn't forget.
It helped me when I was at home but I couldn't take the garage with me on a trip.
Posted: Thu Sep 05, 2019 10:57 pm
by Duey_C
I'm so darned forgetful and so many valves to remember. 80's Kubota engine coolant drains and even 100 year old water drains on some engines/tractors are opposite of what one might expect but coolant drains are easier to learn. With a piece of wire to test!
My solution.
UGH, yes I know it's a rats nest of incorrect in there.
Posted: Fri Sep 06, 2019 9:09 am
by WayneJ
It is somewhat comforting to know I am not alone. I took a picture of my valve in the open position and store it on my phone in a separate "album" titled: "starting model t", so I can remember.
