Bow Saddle
john_aldrich
Last Name: Aldrich
Bow Saddle
Post by john_aldrich » Sat Sep 07, 2019 3:27 pm
The saddle that my top bows rest on when the top is down is loose. I know there is a nut on it inside but for the life of me simply peeling back the panels I cannot reach that nut to tighten it.
Suggestions? Tricks?
john_aldrich
Last Name: Aldrich
Re: Bow Saddle
Post by john_aldrich » Sat Sep 07, 2019 3:34 pm
Here is a picture for clarification.
MTFCA Number: 4838
MTFCI Number: 115
Re: Bow Saddle
Post by DanTreace » Sat Sep 07, 2019 3:57 pm
Isn’t a nut inside, only a female thread boss on the metal upright strut. Use a pipe wrench or vice grip pliers to snug the top prop rod.
Appears to me your prop rod has a bullet nose sleeve over the outer end, might be there to increase the rod diameter for earlier saddle, early have 5/8” hole, later 23-27 have 1/2” holes for the later 1/2” prop rod.
Last Name: House
MTFCA Number: 115
Re: Bow Saddle
Post by George House » Sat Sep 07, 2019 4:48 pm
You have a ‘26-‘27 touring. That forged saddle should have a 1/2” hole for your “prop rod”.
One of the biggest problems with today’s youth is they’ve never known the fear of hearing leather being rapidly pulled through seven Wrangler belt loops.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Bow Saddle
Post by RajoRacer » Sat Sep 07, 2019 10:23 pm
Hey John - 2 different parts - "top prop rod" threads into a boss on the body support iron as Dan stated - "top saddle" has it's own square head set screw which tightens onto the top prop rod - one or the other is coming from together !
john_aldrich
Last Name: Aldrich
Re: Bow Saddle
Post by john_aldrich » Sun Sep 08, 2019 12:43 pm
Got it and thanks!
The FORUM has aided me once more!
MTFCA Number: 121
MTFCI Number: 16310
Re: Bow Saddle
Post by Original Smith » Sun Sep 08, 2019 5:34 pm
Why not put your top up, so you can see what you are doing?
