Bow Saddle
Posted: Sat Sep 07, 2019 3:27 pm
by John_Aldrich
The saddle that my top bows rest on when the top is down is loose. I know there is a nut on it inside but for the life of me simply peeling back the panels I cannot reach that nut to tighten it.
Suggestions? Tricks?
Re: Bow Saddle
Posted: Sat Sep 07, 2019 3:34 pm
by John_Aldrich
Here is a picture for clarification.
Re: Bow Saddle
Posted: Sat Sep 07, 2019 3:57 pm
by DanTreace
Isn’t a nut inside, only a female thread boss on the metal upright strut. Use a pipe wrench or vice grip pliers to snug the top prop rod.
Appears to me your prop rod has a bullet nose sleeve over the outer end, might be there to increase the rod diameter for earlier saddle, early have 5/8” hole, later 23-27 have 1/2” holes for the later 1/2” prop rod.
Re: Bow Saddle
Posted: Sat Sep 07, 2019 4:48 pm
by George House
You have a ‘26-‘27 touring. That forged saddle should have a 1/2” hole for your “prop rod”.
Re: Bow Saddle
Posted: Sat Sep 07, 2019 10:23 pm
by RajoRacer
Hey John - 2 different parts - "top prop rod" threads into a boss on the body support iron as Dan stated - "top saddle" has it's own square head set screw which tightens onto the top prop rod - one or the other is coming from together !
Re: Bow Saddle
Posted: Sun Sep 08, 2019 12:43 pm
by John_Aldrich
Got it and thanks!
The FORUM has aided me once more!
Re: Bow Saddle
Posted: Sun Sep 08, 2019 5:34 pm
by Original Smith
Why not put your top up, so you can see what you are doing?
