Bottom metal channel for window glass for a 1927 Coupe
JoeG48
First Name: Joe
Last Name: Gallagher
Post by JoeG48 » Sun Sep 08, 2019 1:10 pm
Help .. Does anyone know if the Part # 8020 CH from Langs ( The bottom metal channel for Window glass ) have to cut to length ..as on my '27 Coupe it is so long that it is jaming on the felt side glass channel ??? Thanks for any help .... Joe .... joeg48@hotmail.com
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Bottom metal channel for window glass for a 1927 Coupe
Post by Humblej » Sun Sep 08, 2019 3:24 pm
If it is jaming it is too long. The 26- 27 coupe door is the same as the 28-29 model a truck door. The model a repro parts are usually better quality than the model t. Snyders model a channel costs twice the langs model t channel. As in most cases, you get what you pay for.
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Sun Sep 08, 2019 6:31 pm
Hi Joe, I did some work on my 27 Tudor front windows a couple of years ago replacing all or the felt channels and the mechanism and rollers, but not the bottom channel. None of the side or top channel parts sold by any of the vendors would fit my doors. Snyder's uses the same part numbers for A and T. I ended up getting new felt channels that were an exact match from Advance Auto. These were a universal channel listed by size not vehicle. By cross referencing I found an exact match but had to add my own hooks. The brand was Stanpro.
For the Bottom channel I noticed that Snyder's lists the same part number A-45963-T for Model T Coupe and sedan doors as the 28-29 pickups.
They do list some different lengths for some of the other Model A bodies. Maybe you have the wrong one.
I need to replace the channels in the rear side windows, they roll up kind of hard but come down easy, but I really do not want to put the upholstery out.
John
