				Another what is it?
				Posted: Fri Sep 13, 2019 12:59 pm
				by 70shovelhead
				Fella had this laying on the table at an antique engine show I am at this weekend. Anyone want to guess what it is.
				Re: Another what is it?
				Posted: Fri Sep 13, 2019 1:01 pm
				by Oldav8tor
				Spring separator - lets you lube between leaf springs.
				Posted: Fri Sep 13, 2019 1:25 pm
				by 70shovelhead
				The gentleman is asking $50 for it. A little high I believe. He says Ford made one with script. Is that a fair price?
				Posted: Fri Sep 13, 2019 8:14 pm
				The handle section is supposed to screw off the blade. It is filled with grease, and when screwed back onto the handle, the grease is forced through the shaft and out the little slot in the blade, thus lubricating the spring at the same time. I have one just like it, with the brand cast into the handle. It is not a Ford part. It could well have preceded automotive work.
				Posted: Fri Sep 13, 2019 8:25 pm
				by perry kete
				Posted: Fri Sep 13, 2019 10:15 pm
				I've got nearly every Ford Z tool and that was not one of them.
				Posted: Fri Sep 13, 2019 10:38 pm
				Allan is correct in it's use, and it was called a Tomahawk spring lubricator. I have one and it works far better in theory than in practice.
http://www.mtfca.com/discus/messages/118802/122431.html
				Posted: Sat Sep 14, 2019 1:37 pm
				by Henry K. Lee
				I really think Scott needs to buy this since he is deep into real cowboy country. When dim dar Ingins coming a runnin, there ain’t going to be no razor burns when he gets scalped. Just pull it out and say, “use this one”!
				Posted: Sat Sep 14, 2019 5:37 pm
				Hank, yep, and if it's just a near-miss, they can leave a bit of grease for that period sporty look!
				Posted: Sat Sep 14, 2019 6:36 pm
				by Henry K. Lee
				Yep! Just Going Get fuzz from me!!
