Front Plate Oil Pump ID
Posted: Sun Sep 15, 2019 7:50 pm
by henryford2
Can anyone identify this oil pump? Thanks
Re: Front Plate Oil Pump ID
Posted: Sun Sep 15, 2019 8:39 pm
by Les Schubert
Really cute!!
I wonder if it is a “vane style “
Great find
Posted: Sun Sep 15, 2019 8:40 pm
by Les Schubert
I have a generator that would work good with it as it has a distributor on the back of it
Posted: Mon Sep 16, 2019 10:53 am
by Gene_French
Les:
the pump looks very much like the pump on my Dodge Brothers … a similar pump was used on Dodge Bro. engines from 1914 thru the 4 cyl. era … it appears to be bolted to a plate that is attached to the Ford front timing cover … the DB pump came in a 2 or 3 bolt mounting depending on year and engine series and was a vane type pump ...always an optimist...Gene French
Posted: Mon Sep 16, 2019 3:07 pm
by Les Schubert
Gene
Thank you for the information
All the best
