Rear bearing will not come out
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Wed Sep 18, 2019 7:45 pm
I know this question has been asked before, but I cannot find the answers. I removed my left rear wheel to check the bearing and sleeve since they are leaking. Everything came apart easily, but I cannot get the bearing out. There is no play in the axle and I remember this axle went together nice and tight when we rebuilt it. Do you have a special tool you use or a special technique to get this bugger out? Thank you.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Rear bearing will not come out
Post by RajoRacer » Wed Sep 18, 2019 8:05 pm
Stevens produced a puller for just removing stubborn rear roller bearings - I'll attempt a photo tomorrow.
Post by Scott_Conger » Wed Sep 18, 2019 8:13 pm
David
while we're waiting for Steve's photo, I think you'll have luck if you will hook the bearing with a wire and rotate the other wheel, forcing this one to turn, too. I have never failed to have a tight bearing walk out while pulling on it and someone else rotates the axle for you.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Wed Sep 18, 2019 8:25 pm
Found a stiff small hook works, something thin to get to the edge of the carriage and the axle.
This one from the wife's sewing basket is good :) Plus wiggle the axle or as Scott said, rotate opposite wheel to turn the axle shaft as you pull out that bearing.
Some use a coat hanger or stiff wire.
Dennis_Brown
Last Name: Brown
MTFCA Number: 21458
Post by Dennis_Brown » Wed Sep 18, 2019 10:21 pm
Wire hangers are getting harder to find than model T parts
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Thu Sep 19, 2019 8:56 am
Also check the bearing outer sleeve for a burr or bent over section that is keeping the bearing from sliding out. Bend or file the end of the sleeve as needed.
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Thu Sep 19, 2019 11:14 am
In most cases the bearing has worn a groove or lip in the outer side of the sleeve, The bearing is hanging up on this lip. Glen
First Name: DAVID
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Sep 21, 2019 11:32 am
Thanks Scott and Dan. I got my daughter to turn the wheel and I found a small hook like Dan shows. Once I got it far enough out I used a puller that I ground off the bottom so it would work on a bearing. The puller probably isnt good for anything else now, but I like to pull my bearings each year to inspect and re-grease them. I think more owners need to pull their bearings more often.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sat Sep 21, 2019 1:52 pm
Here's the tool Stevens put out - works very good.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sat Sep 21, 2019 2:11 pm
David
Glad you had success in pulling the Hyatt bearing for check and re-grease pack.
Using an antique button hook, mine has a bakelite handle, antique store find, $5.
Slips between axle shaft and bearing outer carriage.
Just removed these bearings today for service of the rear axle.
