				21” Model A caps on Model T wire wheels
				Posted: Fri Sep 20, 2019 9:56 pm
				by Ed Fuller
				Anyone ever successfully modify 1928-29 21” Model A hub caps to fit on Model T wire wheels?
				Re: 21” Model A caps on Model T wire wheels
				Posted: Fri Sep 20, 2019 10:57 pm
				by Mark Gregush
				Ya I know do it yourself, but why mess around, buy new ones.
				Posted: Sat Sep 21, 2019 2:26 pm
				by Taford
				Hi Mark,
A few years back I posted a question relating to your question. I asked if anyone had a stock set of 1927 T wire wheels that used a Model A style hubcap. I received responses from four or five T owners that had similar wheels but they thought that they were just larger diameter with no hubcaps. My caps were AR style but the wire wheels were stock '27 T style. The typical '26/'27 hubcap would fall right through my wheel hubcap opening. All 5 of my wheels have a 2-3/4" opening for the hubcaps and I believe that a stock hubcap is around 2-1/2" in diameter. There was quite a discussion regarding my wheels, and some called me out, but when others came forward and had similar wheel openings it makes me wonder if these were late production wheels. Very hard to document. To answer your question however, yes in could be machined or bored out. I would not torch cut it however. Good luck.
				Posted: Sat Sep 21, 2019 2:35 pm
				by Ed Fuller
				Thanks for the help.
I am NOT modifying the T wheels.
Just curious if the larger Model A cap could be made to fit the smaller opening in the T wheels.
				Posted: Sat Sep 21, 2019 8:18 pm
				by Divcoone
				Model T wheels with a A cap and a T cap.
