Ideal crankshaft radius?
Posted: Tue Oct 01, 2019 8:57 am
by BobShirleyAtlantaTx
What is the preferred radius of a T crankshaft? Thanks for your time and help. Bob 903 824 1949
Re: Ideal crankshaft radius?
Posted: Tue Oct 01, 2019 9:25 am
I am pretty darn sure it is 1/8".
Posted: Tue Oct 01, 2019 10:09 am
by Chris Barker
Hmmm. Interesting answer - probably what the questioner wanted, but I was thinking 'What's half the stroke? Ah yes, 2"'
Posted: Tue Oct 01, 2019 10:25 am
by HPetrino
Chris,
I was thinking exactly the same thing as you, 2".
Posted: Tue Oct 01, 2019 11:44 am
Earlier post with factory dimension stated:
http://www.mtfca.com/discus/messages/29 ... 1201460648
Posted: Wed Oct 02, 2019 11:46 am
by TonyB
From the research in building the six 1914 replicas, the radius between the bearing surface and the side of the crank is specified as 0.125”.
Posted: Wed Oct 02, 2019 3:23 pm
by Kohnke Rebabbitting
It has an 1/8th, .125 inch Radius. No bigger, or smaller. Rods, and mains should be cut that Diameter, also, or you will have a mating problem.
A 2" Radius, should be closest to a 15" Diameter crank.
Her.
Posted: Sun Oct 06, 2019 7:38 pm
by John E. Guitar
Would the Model A & B crankshaft also be 1/8"?
