Adjustable Drive Shaft Bearing Assembly choices
ArthurB
First Name: Arthur
Last Name: Babitz
Post by ArthurB » Tue Oct 01, 2019 6:18 pm
I'm preparing to overhaul my drive shaft, with the expectation of installing an adjustable modern drive shaft bearing assembly unless everything is miraculously in spec. It looks like there might be a few different choices between the different vendors, or maybe they just have different pictures of the same kit? I've looked at Chaffins, Langs, Snyders, Fun Projects-- can anyone recommend one over the others based on personal experience, or are they the same?
Thanks.
Chris Instness
First Name: Christopher
Last Name: Instness
Re: Adjustable Drive Shaft Bearing Assembly choices
Post by Chris Instness » Tue Oct 01, 2019 6:38 pm
I recently bought a modern drive shaft bearing from Chaffin's. Someone can correct me if I'm wrong, but I believe Chaffin's makes there own. Only have about 1500 miles on mine, but it have been trouble free and I am happy with it. Mine is not adjustable and I do not beleive Chaffin's makes an adjustable one like Fun Projects. I have also heard good things about the Fun Project's Modern Pinion Bearings.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Oct 01, 2019 6:43 pm
I believe Fun Projects makes the most popular drive shaft bearing setups that is used. I have have them in 2 of my T’s and is a definite improvement. There may be other brands that are used. Others will probably post on the subject.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Tue Oct 01, 2019 8:13 pm
The Fun Projects adjustable bearing works very well and is easy to install. Would certainly use it again.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Oct 01, 2019 10:39 pm
The Fun Projects adjustable pinion bearing is for folks who feel better if they have something to adjust. I use the non-adjustable version and it's fine. It also costs less.
Last Name: Gregush
Post by Mark Gregush » Wed Oct 02, 2019 12:26 am
I have installed 3 of the non adjustable types. Just follow the instructions.
1921 Huckster
old_charley
First Name: Bryan
Last Name: Ostergren
MTFCA Number: 8082
Post by old_charley » Wed Oct 02, 2019 2:13 am
I have maybe 20,000 miles on one of Chaffin's bearings with no trouble whatsoever
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Wed Oct 02, 2019 3:45 am
I have Fun Projects Non Adjustable ones in both of my T’s and absolutely no issue.
Being cautious that I am, I also kept the top end drive shaft Bush / thrust face set up as standard in the in the unlikely
event the locking collar came loose.
John Reagan advised me there is no need for the fidly adjustable type and as usual, his advice was 110%
Alan
ArthurB
First Name: Arthur
Last Name: Babitz
Post by ArthurB » Wed Oct 02, 2019 10:54 pm
Thanks for sharing your experiences. I'll note that everyone is happy with the choice they made. I hope that means this is a relatively low-risk project.
I'm eager to tear open the drive shaft and rear axle to see what I have, but I'm trying to squeeze in a few more nice drives before the rains start here in the Pacific NW. I've got the whole project planned thanks to all the great forum advice. Custom cradle and jack stands sitting by the side of the garage, waiting for the first week-long rain storm.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Oct 03, 2019 10:36 am
Since Ford made over 15 million cars with no problems to speak of, I will continue to use Fords methods. I have many thousands of miles on my cars, with no issues, and I'm using Ford script babbit front D.S. bushing up front with no problems either!
Last Name: Gregush
Post by Mark Gregush » Thu Oct 03, 2019 11:34 am
Guess if you have a supply of NOS or good original replacement parts, using them will be fine. For many that is not the case.
1921 Huckster
