Cool steering box
Topic author - Posts: 4968
- MTFCA Number: 52564
Cool steering box
This is ether going on my 21 or? Anyone know what it was off of? Yes it has a Model T spider on it. The lower bracket is adjustable so you can set the box and column at most any angel. The bearing surfaces are a bit worn but the teeth look good. It is a cross swing. The ball needs some loving but looks to be the same size as T.
1920 Dodge touring
1920 Dodge touring
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Cool steering box
Mark I have seen a few in vintage wooden boats. Now is it for that purpose, no real clue. They used two bell-cranks in the system to connect to the rudder. ??
Hope this Helps,
Hank
Hope this Helps,
Hank
- First Name: Howard
- Last Name: Tomlinson
Early Chevrolet ?
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Chevy 490
- First Name: Pete
- Last Name: Eastwood
- MTFCA Number: 52632
It's a Chevy, I believe a "490" I used one I my speedster & loved it.
I have since bought another one for future use .
Thanks for what it fits. The rust worms got to the outside of the shaft some, but being solid don't think will hurt it much. I will have to shorten it about 9-10 inches and will use the T mast jacket and rods.
1920 Dodge touring
1920 Dodge touring
