Gasket replacement for carbide generator?
Posted: Sun Jan 06, 2019 8:29 pm
by GJScholz
Hi,
I need to replace the gasket on the carbide generator.
What is the group's consensus on the process, materials, and method?
If you have any best bets, resources or success stories, I'd love to know.
BTW, I repaired my leaks with silver solder! Successfully, but not without trepidation.
Thanks for your advice.
Thank you,
Greg
Re: Gasket replacement for carbide generator?
Posted: Sun Jan 06, 2019 8:47 pm
by KeithG
I tried to find a new gasket for my carbide generator a few years ago with no luck. I tried all the vendors & no one ever carried them. I finally came to the conclusion that RTV would work. Lay it in the grove very carefully & try to keep it even and let it cure real well before putting the generator back together.
Hope this helps.
Keith
Posted: Mon Jan 07, 2019 10:55 am
by GJScholz
Thanks Keith!
I'm not too steady in the hands, so I may need to investigate carving one out of a mouse mat or something.
Thank you,
Greg
Posted: Mon Jan 07, 2019 11:59 am
by namdc3
Greg, I cut mine out is a piece of Viton, probably from Amazon or McMaster-Carr. If your hands are unsteady, find two circular cans that right diameters and essentially trace them with a sharp exacto knife.
Posted: Mon Jan 07, 2019 12:46 pm
by GJScholz
Thanks,
I'm going to order up some Viton rubber sheeting, and cut myself a new one. I'm supposing that the outer edge is pretty important, and as long as I leave it wide enough, the inner edge is not so important.
I'll let you know how it goes.
Thank you
