Anyone want to venture a guess on what this axle is for?
Posted: Tue Oct 22, 2019 7:49 pm
by Jeff Perkins
See picture, top axle is Model T, bottom looks exactly like a T but shorter. It has not been cut or welded. Is it for a clown car? How about a FWD conversion? Opinions please!
Re: Anyone want to venture a guess on what this axle is for?
Posted: Tue Oct 22, 2019 8:02 pm
Most likely shortened on the gear end - pretty simple machining process to shorten & recut the key & keeper slots.
Posted: Tue Oct 22, 2019 8:08 pm
by KWTownsend
I believe some snow machines used narrower axles.
Posted: Tue Oct 22, 2019 8:28 pm
by Michael Peternell
I'm going to guess for a tractor conversion. Shaw offered different configurations/ Wheel spacings.
Posted: Tue Oct 22, 2019 8:41 pm
by HPetrino
I've never had one apart, but does a Ruckstell use a shorter axle on one side?
Posted: Wed Oct 23, 2019 12:31 am
by Erik Johnson
Posted: Wed Oct 23, 2019 9:46 am
by Jeff Perkins
Posted: Wed Oct 23, 2019 10:48 am
The Ruckstell uses standard Ford axles on both sides. I would suspect that axle might have been cut down for a speedster or maybe for a small trailer to be pulled by a T.
Posted: Wed Oct 23, 2019 11:12 am
by Rich Bingham
Model T rear axles were often modified for application on farm implements. Around here, many one-row spud diggers used them. (Blackfoot, Idaho - world potato capitol -
Posted: Wed Oct 23, 2019 11:31 am
by henryford2
Offset rear axle for sprint car
