Assistance with Front Spindle mounting repair
Posted: Tue Oct 22, 2019 8:06 pm
by choirsilva
I purchased a 1926 Model TT in August and have it running but, it is in need of repair to the axle yoke where the spindle mounts as the top holes are worn oversize and on one side the threads are completely gone.
I'm in the Portland, Oregon area and am looking for either someone within an hour of me that has a Stephens tool that can assist me with the repair or someone that would rent me the tool. Alternatively, if there was a shop in the area that does this work, I could remove the axle and take it in to have it done. I'm a newbie to model T's and model TT's. Haven't been to my first club event but, hope to make it to a Rose City Model T club meeting in November to start to meet the local club members.
I've already purchased a spindle bolt set and related tools through Langs but, haven't ordered repair inserts for the yokes yet.
Thanks,
Christopher Silva
Re: Assistance with Front Spindle mounting repair
Posted: Tue Oct 22, 2019 8:44 pm
The Rose City Model T club has the repair tools and inserts to fix your axle for club members to use. The meeting is the first Thursday of the month.
http://www.rosecitymodeltclub.org/
We also have a Facebook page;
https://www.facebook.com/rosecitymodeltclub/
If Keith does not see this send me a PM and I will get you in touch with him, he is our keeper of the tools and how to DVDs/videos. We have a couple of members working on TT's now. We like to get new members. While the meetings are for club business there is time for talking to members to get info and help.
Mark
Posted: Tue Oct 22, 2019 9:07 pm
by choirsilva
Mark, that is fabulous, will plan on attending the November meeting
Anxious to have this truck back on the road.
Thanks,
Christopher
Posted: Tue Oct 22, 2019 9:15 pm
Great!
Posted: Wed Oct 23, 2019 1:07 am
by KWTownsend
Christopher-
Welcome. I will plan to bring the front axle tools to the November meeting.
-Keith
Posted: Wed Oct 23, 2019 8:07 pm
by choirsilva
Keith,
I have a Spindle Bushing Driver, Bushing Thrust Cutter, Spindle bushing reamer and reamer alignment tool that I purchased from Langs along with a spindle bolt and bushing set. Is there anything else that I'll need along with the tool set that I'll pick up when I meet you on the 7th? Do I need to order the new threaded inserts for the bottom yoke bore and tapered inserts for the tops?
We live in Fairview and am looking forward to getting to know folks in the Rose City Club. We have a couple other classics but, this is our first 20's vehicle. We pulled if from a barn in Yamhill.
Thanks so much,
Christopher
Posted: Wed Oct 23, 2019 9:13 pm
There are inserts in the box with the tools. You will need to replace any inserts you use.
From the list you posted should about cover the job.
Mark
Posted: Thu Oct 24, 2019 12:00 am
by choirsilva
Mark,
That sounds great, are the insert sets from different suppliers all the same to work with the Stephen's type axle reamer bits or is there one particular supplier I should order them from. I'm going to go ahead and order a set so that I'll be all set to return the tool set complete.
Thanks again for all of your assistance. The TT is a very different animal for me than our other classic cars.
Christopher
Posted: Thu Oct 24, 2019 1:47 am
The ones Lang's or Snyder's sells are correct for the Stevens tool. I would wait and see how many you need because it is better to only replace what is need in the axle. I am pretty sure the threads only go part way thru the hole so may be looking at ok threads. The top being wallowed out is a different story. While these work great, it is better to keep as much of the original forging as you can.
Posted: Thu Oct 24, 2019 6:54 am
by Dan Hatch
The inserts only come from one source.
If the top hole needs an insert. 9 times out of 10 the bottom needs one to.
Per the Stevens instructions, you always fix the top hole first. This gives you a starting point for the bottom hole.
Also, they say to check the hardness of axle before starting. This to avoid damage to your cutting tools.
For more info email me. Dan
Posted: Thu Oct 24, 2019 9:38 am
Dan also makes the inserts.
