Stipe cam
art32mor
First Name: Art
Last Name: Morra
MTFCI Number: 14286
Stipe cam
Post by art32mor » Thu Oct 24, 2019 1:14 am
Reading online but never heard stipe 280 cam cant use adjustable lifters?
And then looked in langs says same thing??
I also found I need shave .018 off my new front cam bearing is this common issue
With stip cam?
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Re: Stipe cam
Post by George N Lake Ozark » Thu Oct 24, 2019 1:18 am
I don’t know about shaving the bearing, but but I’m running the.280 for several years and have adjustable lifters .
Re: Stipe cam
Post by Mark Gregush » Thu Oct 24, 2019 1:36 am
This might give you more info;
http://www.mtfca.com/discus/messages/33 ... 1376057894
Reading it, not all blocks are the same in that area, some have more room. Depending on how the foot is made, you could run into the same issue with repo stock lifters I would think.
I know the voices aren't real but damn they have some good ideas! :roll:
1921 Huckster
Kerry
Last Name: van Ekeren
Re: Stipe cam
Post by Kerry » Thu Oct 24, 2019 1:37 am
I've never heard of any issues in using adjustables on the 280, as George states I've ran the same for several years. And as for the bearing, yes new ones sometimes need turning in the lathe for a final fit.
Re: Stipe cam
Post by Mark Gregush » Thu Oct 24, 2019 1:50 am
Could also mean, you do not need a "SPECIAL" lifter. I would consider an adjustable lifter to be equal to non adjustable as a direct replacement.
1921 Huckster
Kerry
Re: Stipe cam
Post by Kerry » Thu Oct 24, 2019 4:33 am
Haven't seen the lifters that had a higher stem base for several years, the ones on the market today are machined with a nice taper, just a quick touch with a drill bit or stone to chamfer the block guide holes to just make sure on clearance on the high lift cams is all that is needed.
Plankhill
First Name: Brendan
Last Name: Doughty
MTFCA Number: 15143
Re: Stipe cam
Post by Plankhill » Thu Oct 24, 2019 6:36 am
I have been running a 280 with adjustable lifters for a few years.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
MTFCA Number: 49847
MTFCI Number: 8340
Re: Stipe cam
Post by Jim Eubanks » Thu Oct 24, 2019 8:53 am
Same here, I have two cars with the 280 and adj. lifters.
art32mor
First Name: Art
Last Name: Morra
MTFCI Number: 14286
Re: Stipe cam
Post by art32mor » Thu Oct 24, 2019 9:52 am
Well guy just what i had read thanks
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Re: Stipe cam
Post by BE_ZERO_BE » Thu Oct 24, 2019 1:52 pm
I purchased a Stipe cam when they first came out years ago.
I have had adjustable lifters from the beginning - no issues.
Respectfully Submitted,
Be_Zero_Be
For every Absolute Model T Fact there are at least three exceptions
You never used to be older :shock:
Roz
Last Name: P
MTFCA Number: 31449
MTFCI Number: 24373
Board Member Since: 2012
Re: Stipe cam
Post by Roz » Thu Oct 24, 2019 5:04 pm
I looked at Langs’ catalog for Stipe cams. It says they “can be used with stock lifters”. It doesn’t say you can’t use adjustable lifters. I take that to mean no special lifters required. I have put in several Stipe cams with adjustable lifters with no problems.
Re: Stipe cam
Post by Scott_Conger » Thu Oct 24, 2019 6:41 pm
I had to relieve the back side of 3 lifter bores last year, to clear a tour-grind Stipe cam (250?)
It just depends on your block. It isn't hard or even time consuming to remedy
Full Flow Float Valves - deliver fuel like Henry intended!
art32mor
First Name: Art
Last Name: Morra
MTFCI Number: 14286
Re: Stipe cam
Post by art32mor » Thu Oct 24, 2019 7:52 pm
Thanks must mis read it i didnt think there was an issue
