Safety wire
Posted: Sun Oct 27, 2019 9:31 am
by Don ellis
What is the most common size used on a model T?
Re: Safety wire
Posted: Sun Oct 27, 2019 9:46 am
by Humblej
.032 and .051. I use the smaller wire for smaller applications and the larger wire for wishbone ball joint, flywheel bolts, differential bolts, and other larger bolts.
Aircraft safety wire pliers will make a professional twist for a nice clean job.
Many older posts regarding the best way to do safety wire.
Re: Safety wire
Posted: Sun Oct 27, 2019 11:11 am
by Original Smith
I ran out awhile back, and I had to go to three different auto parts stores to find it!
Re: Safety wire
Posted: Sun Oct 27, 2019 11:22 am
by Don ellis
I tried that, they have no idea what I’m talking about. Amazon has it though.
Re: Safety wire
Posted: Sun Oct 27, 2019 12:20 pm
by Humblej
I get mine at Aircraft Spruce.
Re: Safety wire
Posted: Sun Oct 27, 2019 1:31 pm
by RajoRacer
I also procure my S.S. wire through the local aircraft parts store - iron "bailing wire" I p/u at Wilco Farm Store or Tractor Supply.
Re: Safety wire
Posted: Mon Oct 28, 2019 4:24 am
by D Stroud
Harbor Freight has Stainless Steel safety wire very reasonable, not sure about the sizes though. Dave
Re: Safety wire
Posted: Mon Oct 28, 2019 6:29 am
by Randall strickland
if you want plain old tie wire you can get it at most concrete places it is used to tie rebar.
Re: Safety wire
Posted: Mon Oct 28, 2019 9:55 am
by John kuehn
Ace hardware has safety wire in different sizes.
Re: Safety wire
Posted: Tue Oct 29, 2019 12:59 am
by TonyB
I use 0.032” wire from McMasters
