Camshaft movement- tolerance question
Posted: Mon Oct 28, 2019 11:51 am
by Bill Robinson
I have a Stipe 250 cam in a 1926 engine. 7.5 degree advanced bronze timing gear.
-My question- with the timing gear cover removed I have a camshaft lateral movement (in & out) of .0065".
-Up & down movement of the camshaft is .005".
Are these measurements withis tolerance or do I need to looking into finding a new front bearing?
Re: Camshaft movement- tolerance question
Posted: Mon Oct 28, 2019 12:15 pm
I would say the in/out is hardly nothing. Is the up/down the cam or shell in block?
My real question is where did you get the bronze gear with 7.5 degree advance? The info in Chaffins says not to use the advanced timing gear as the new cam is already advanced, Langs does not say. Is this a new engine or has it been run with this combination?
Posted: Mon Oct 28, 2019 12:25 pm
Mark
the difference is that Glen's folks dialed in advance on the cam that they sell. The Stipe product is a straight up cam and is up to you to decide to advance it or not. I think that Dan McEachern will do the gear in bronze. His work is superb.
Posted: Mon Oct 28, 2019 1:52 pm
by Bill Robinson
The STIPE 250 cam was installed in 2012. It is not a Chaffin's cam. I'm thinking that the Stipe 280 Cam was not available at the time. The advanced gear is one of Dan's and was installed in 2015.
I don't know if the movement is in the shell, because as stated, only the timing cover has been removed.
Posted: Mon Oct 28, 2019 4:16 pm
by Kerry
Back to your question, yes you need to get a new bearing, with that much float in the cam it will sound like the engine has done a bigend.
Posted: Tue Oct 29, 2019 10:15 am
by Bill Robinson
Frank- please explain the phrase "sound like the engine has done a bigend". I'm not familiar with the word "bigend". Sound/noise is what I'm trying to eliminate. That is exactly my problem. 2 of my cars started making this loud rattling noise during acceleration about 4 years ago after changing from a nylon timing gear to a bronze gear. The noise is there even though the timing is advanced to the "sweet spot" and not overly advanced. One car is a '26 and the other is a '27.
So, my real question- is the noise coming from excessive play in the cam or is it because of the timing gear change.
Now, let me say this- I have installed the bronze gear in three other older cars and there is no rattling noise detected.
Posted: Tue Oct 29, 2019 3:30 pm
by Kerry
Bill, I think you covered it in your description, a bigend rattle is the connecting rod on the crankshaft, with the wear in the cam bearing you get a rattle that will drive you nuts. Like you say, an advance rattle. The later cams are easy to make a good fit bearing if a new one still gives to much end play, I take the early longer bearing and turn down to shorten the ends on the lathe for a nice tight fit.
