New accessory item, GUESS
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Oct 29, 2019 4:39 pm
Pretty excited about our new accessory offering. We do these things to keep busy, stay active, stay out of wifeys hair and the bar, and of course to make a buck or two. I thought I’d throw this out with a clue or three. The first to guess correctly HERE will get the first one FREE. 1) they are at the powdercoater right now, should be done in a couple days. 2) it’s an aftermarket accessory, but even the Original Smiths of the hobby MIGHT want one. 3) it’s smaller than a breadbox ( that should eliminate anyone under 50! ) First to guess correctly will get #1 FREE postpaid. PLEASE, NO EMAILS,PHONE CALLS,PMS,PMS REQUESTS, TELEGRAPH MESSAGES,SMOKE SIGNALS OR KNOCKS ON MY DOOR.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Re: New accessory item, GUESS
Post by Oldav8tor » Tue Oct 29, 2019 4:51 pm
Geez! How about a little clue other than size, like what part of the car it's associated with?
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
MTFCA Number: 32518
Post by Tom Hicks » Tue Oct 29, 2019 4:54 pm
Right hand henway adjuster?
rondupree
First Name: Ronald
Last Name: Dupree
MTFCA Number: 22940
MTFCI Number: 15830
Post by rondupree » Tue Oct 29, 2019 5:05 pm
Air filter assembly.
Ron Dupree
Shane Lach
First Name: Shane
Last Name: Lach
Post by Shane Lach » Tue Oct 29, 2019 5:42 pm
Is it the aluminum oil fill extensions?
Post by Wayne Sheldon » Tue Oct 29, 2019 5:42 pm
Hand crank anti-kickback?
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Oct 29, 2019 6:33 pm
Then this post belongs on the Parts forum, since it is an accessory.
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
MTFCA Number: 27167
MTFCI Number: 20405
Post by Don D » Tue Oct 29, 2019 7:37 pm
A Gunkalator Armature
HPetrino
First Name: Henry
Last Name: Petrino
* REQUIRED* Type and Year of Model Ts owned: 1918 TT
Post by HPetrino » Tue Oct 29, 2019 7:47 pm
I know what it is. It's a 3 in 1 pump It pumps water, fuel and oil. I get the prize, right? :lol: :lol: :lol:
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Tue Oct 29, 2019 8:00 pm
Smith's... it's not a Form-a-Jack, is it? (Godawful screw jack things that were the scourge of british car owners in the 50's...)
I like the idea of a combo oil/water pump that runs off the mag, combined with a rectifier and regulator so you can charge a battery from the mag.
How's that? Am I close? --lol--
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Tue Oct 29, 2019 8:02 pm
OK... Electrical, Mechanical, or Hydraulic?
babychadwick
First Name: Chad
Last Name: Azevedo
* REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
Post by babychadwick » Tue Oct 29, 2019 8:15 pm
Based on size it would be possible to be brackets for stabilizing/reinforcing a wishbone but not the entire wishbone. Next down on size would be a battery box on the running board but thats questionable. A hand brake extension would be small enough and something I could see being more acceptable for purists.
Post by TRDxB2 » Tue Oct 29, 2019 8:16 pm
Small - will send post paid..... >>>> Oil Sight gauge
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Oct 29, 2019 8:19 pm
Oh, Oh Mr Kotter! You have invented the perfect companion for man in a miniature size?
Horshack Hank in Tin-A-See
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Tue Oct 29, 2019 8:20 pm
Manifold cooker?
RodellJunior
Last Name: Rodell
MTFCA Number: 14035
MTFCI Number: 13594
Post by RodellJunior » Tue Oct 29, 2019 9:16 pm
Heater.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Oct 29, 2019 9:17 pm
Combination crank holder / front license plate bracket. The kind that keeps the crank handle up out of the mud ;)
2nighthawks
First Name: Harold
Last Name: Schwendeman
MTFCA Number: 0
Post by 2nighthawks » Tue Oct 29, 2019 9:38 pm
Mechanically hand operated turn signal semaphore arm thingie!
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Post by Tim Moore » Tue Oct 29, 2019 9:45 pm
Yup I got it! I have a few so am out. I know lots of people who don't have one. What color? Good work again Tim!
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Tue Oct 29, 2019 10:12 pm
got to be the new coil points tool
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
MTFCA Number: 5414
Post by BHarper » Tue Oct 29, 2019 11:01 pm
Bermuda Bell?
Philip Lawrence
First Name: Philip
Last Name: Lawrence
MTFCA Number: 5591
MTFCI Number: 25062
Board Member Since: 2014
Post by Philip Lawrence » Tue Oct 29, 2019 11:33 pm
It is either a copy of a original design water pump or a copy of an original firewall mounted Marvel Mystery Oil reservoir with all fittings and tubing to hook up directly to the engine.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Oct 30, 2019 12:35 am
Hand brake extension handle.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Wed Oct 30, 2019 12:49 am
That was going to be my guess too.
1920 Dodge touring
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
Post by Novice » Wed Oct 30, 2019 1:08 am
Emergency axle. Cable operated brake equalizer.
aDave
First Name: David
Last Name: Dufault
MTFCA Number: 303
Post by aDave » Wed Oct 30, 2019 6:37 am
Brake Light
Doug Keppler
First Name: Douglas
Last Name: Keppler
MTFCA Number: 49716
Post by Doug Keppler » Wed Oct 30, 2019 7:08 am
A non vibrating side view mirror
1924 Touring car
There's No Substitute for Proper Lubrication
Banjoe
First Name: Joe
Last Name: Lucas
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
MTFCA Number: 50498
Post by Banjoe » Wed Oct 30, 2019 7:39 am
I don't have one, but it's powder coated and just in time for Christmas, so I really need this......... whatever it is.
If I have to guess, I'll go with an air foil to keep the rear of the car fixed on the ground at high speeds.
None of us is as smart as all of us.
JimDix
First Name: James F
Last Name: Dix
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1921 Coupe
MTFCA Number: 7082
MTFCI Number: 14604
Post by JimDix » Wed Oct 30, 2019 7:56 am
Suicide door coupe sun visor.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Wed Oct 30, 2019 8:00 am
If Larry would even like it, must be small cans of 100 year old air for the tires. Where did you ever find the air Tim?
John Codman
Last Name: Codman
Post by John Codman » Wed Oct 30, 2019 10:54 am
I hope that it is the shake-free mirror. If it is, I will order one.
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Wed Oct 30, 2019 1:53 pm
Hmm,the only thing I can think of that Larry would use (and mostly because CA state law says we should have one) is a driver's side rearview mirror.
Will be interesting to find out what it really is!
T'ake care,
David Dewey
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Oct 30, 2019 2:05 pm
Battery box!
Super Mario Bross ;)
1911 Touring
1914 Speedster
modeltbarn
First Name: Gary
Last Name: London
MTFCA Number: 16592
Post by modeltbarn » Wed Oct 30, 2019 2:43 pm
Fuel Gauge?
Bmettli
First Name: Brian
Last Name: Mettling
* REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
Post by Bmettli » Wed Oct 30, 2019 8:28 pm
Lol.
Variable valve timing
Emission controls
Dashboard Totally integrated power modules (TIPM)
Limited slip thrust washers
E85 compliant carbs
The possibilities are endless.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Oct 30, 2019 8:33 pm
Brian
I have thought about doing variable valve timing. The concept has merit!
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Oct 30, 2019 8:50 pm
I had to go slowly through all the great responses. Nobody has got it yet. Lots of great ideas, but so far only Timmy Moore knows,so he will get #2 gratis. Oh, by the way Tim, they will be any color you want as long as it’s black! That’s clue number 4. #1 is still reserved for the right answer posted here.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Wed Oct 30, 2019 9:02 pm
Hogs head oiler like the ford Faithful oiling system.
1920 Dodge touring
Pep C Strebeck
First Name: Joseph
Last Name: M
MTFCA Number: 0
Post by Pep C Strebeck » Wed Oct 30, 2019 9:18 pm
An early screwdriver for the tool kit?
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 31, 2019 10:20 am
Spring loaded oil can holder
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Thu Oct 31, 2019 10:27 am
Dan, did you get some inside help?
Dropacent
Last Name: Morsher
BINGO ! Dan is the man !
Post by Dropacent » Thu Oct 31, 2019 10:58 am
Bingo ! Dan will be getting one in the mail. A faithful reproduction of a spring loaded oil can holder. Just recd a message they are ready to snag at the powdercoat, so will post a picture of our new baby. Later ,a full spiel will be posted in the classifieds. Thanks for all the great guesses , maybe some new ideas for others. AND , if Original Larry Smith would even use one, I’ll send him one free, too. HAPPY HALLOWEEN !
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 31, 2019 12:02 pm
Nope, no ‘forum leaks’ :lol: This forum ain’t like DC!
Just serious thoughts on a desired accessory many T owners would like or need to like as the oil can came with the car’s tool set and no place to store it other than garage shelf. The last guess of the screwdriver with the earlier tool kits made my brain fart happen!
Thanks Tim!! Will use that accessory, now thinking best spot to drill holes in the firewall :)
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Mon Nov 11, 2019 9:23 am
Got my Major Award last week from Tim.
What a great accessory! Tim did a terrific job of recreating the spring loaded version of the firewall mount oil can holder.
The spring is good and strong, can won't work loose and holds firm.
Thanks Tim! and thanks for offering these to others, will put mine to use :D
