Is this an original Model T tailgate?
NorthSouth
First Name: Steven
Last Name: Chase
MTFCA Number: 50392
Post by NorthSouth » Fri Nov 01, 2019 4:03 pm
Hello fellow Model T-ers,
I have two questions for you today.
1). Is this an original Model T tailgate?
2). What would be a fair price to pay for this particular tailgate?
Thank you in advance for your comments.
-Steven
NorthSouth
First Name: Steven
Last Name: Chase
MTFCA Number: 50392
Re: Is this an original Model T tailgate?
Post by NorthSouth » Fri Nov 01, 2019 4:08 pm
Same tailgate.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Nov 01, 2019 7:26 pm
Appears to be & pretty nice condition for other than the bullet hole and the 2 other small holes - perhaps reflectors.
Value is whatever you can get for it but IMO $100 - $150.
NorthSouth
First Name: Steven
Last Name: Chase
MTFCA Number: 50392
Post by NorthSouth » Mon Nov 04, 2019 12:29 pm
Thank you Steve,
Does anyone else have an opinion on these 2 questions?
Angmar
Last Name: Bailey
MTFCA Number: 50335
Post by Angmar » Mon Nov 04, 2019 12:50 pm
Depending upon the size it could also be model A gate but that would be a good question for the A guys also. The straps/hinges for those would be different. Just a thought.
Still crankin old iron
MTFCA Number: 28924
Post by John kuehn » Mon Nov 04, 2019 1:30 pm
Could be a tailgate in the early 30’s era.
gcomo
First Name: Gary
Last Name: Como
Post by gcomo » Mon Nov 04, 2019 3:25 pm
Model A tailgate is the same as the T.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Mon Nov 04, 2019 4:24 pm
Steve has value about right IMO.
That is a T tailgate. The A tailgate will fit a T bed, but the A tailgate has folded over double at the bottom hinge strap, because the single T strap is weak at that lower spot.
NorthSouth
First Name: Steven
Last Name: Chase
MTFCA Number: 50392
Post by NorthSouth » Mon Nov 04, 2019 9:20 pm
Measurements of this tailgate.
NorthSouth
First Name: Steven
Last Name: Chase
MTFCA Number: 50392
Post by NorthSouth » Mon Nov 04, 2019 11:28 pm
Another
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Nov 05, 2019 11:17 am
The tailgate is definitely a T tailgate. This style was also used on the first 1928 A pickups too. They found the hinge was weak, and they are, so they modified that hinge for the A's, but they will still fit a T. You mentioned in a phone call that there is a slight convex problem with that tailgate which could probably be corrected on a press if only slight, but if not, would require heat, shrinking the metal back to it's original form. I own an authentic 1925 pickup, and spend countless hours painting and sanding my tailgate. It still isn't 100%, but it's as good as I could get it.
1925 T Pick-up, 1-04-09 001.jpg (59.27 KiB) Viewed 754 times
