Gas tank sediment bowl
Philip Lawrence
First Name: Philip
Last Name: Lawrence
MTFCA Number: 5591
MTFCI Number: 25062
Board Member Since: 2014
Post by Philip Lawrence » Tue Nov 19, 2019 12:31 pm
Can anyone tell me what the correct finish on the steel sediment bowls under the gas tank was? Most of the time these are painted black but is that correct? I'm just wondering if they were just left unpainted from the factory, I have never seen any evidence of paint on unrestored ones.
Philip Lawrence
First Name: Philip
Last Name: Lawrence
MTFCA Number: 5591
MTFCI Number: 25062
Re: Gas tank sediment bowl
Post by Philip Lawrence » Wed Nov 20, 2019 1:24 pm
I'm suprised that nobody out there can answer my inquiry about the original factory finish on the steel sediment bowls. This is kinda fun stumping the experts out there.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Wed Nov 20, 2019 1:47 pm
I could be wrong but I doubt they were painted. The main body may have been raven finished but that would likely have been all. The tanks were of course galvanized and not painted, so the whole thing would not have been dipped as an assembly. On my '20 I'm going to just use a clear satin lacquer on the bulb.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed Nov 20, 2019 1:54 pm
I suppose there’s no value in speculating without solid documentation but I’d be willing to bet they came unpainted. Then as now, some seeping or sweating if fuel is inevitable which would (will) ultimately remove a coat of paint.
"Get a horse !"
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Wed Nov 20, 2019 2:39 pm
Factory photos good ref. Early sediment bulbs cast bronze, by 1916 cast iron, no finish on them. Just naked ;)
Philip Lawrence
First Name: Philip
Last Name: Lawrence
MTFCA Number: 5591
MTFCI Number: 25062
Post by Philip Lawrence » Wed Nov 20, 2019 3:03 pm
Thanks to RV, Rich and Dan for their reply. As I mentioned I my first post I suspected that they were unpainted originally. I'm currently rebuilding three sediment bowls and always like to do things correct if at all possible, they will be buck naked!
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Thu Nov 21, 2019 11:42 am
How do you know the ones in the picture are steel and not bronze? Appearance of both oval and round tanks? It doesn’t make sense that round and oval tanks would be in the same photo. The change-over was in ‘20. Is it possible that the photo is much earlier, maybe around ‘14, and the tanks that appear to be oval are in fact round tanks moving by on a conveyor?
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Nov 21, 2019 9:00 pm
Adam
Those are all round tanks, early photo, posted a cropped version, and camera angle made the upright tanks seem oval :P
