Pick up HCCT in Roseville Ca I live in Nampa Id
Topic author - Posts: 451
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Hi anyone coming from California going through Roseville Ca and heading east through Idaho? I would like to arrange pickup of a HCCT, I can meet with you on the road, depending your route
Best Regards,
Joe
Best Regards,
Joe
Regards,
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Re: Pick up HCCT in Roseville Ca I live in Nampa Id
Hand crank coil tester.
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
- MTFCA Number: 5414
For Jim and others who have not been up close and personal with a Hand Cranked Coil Tester, they are heavy, top heavy, and unwieldy things. While there are several different styles regarding meter(s) and location of the coil receptacle, they all weigh about 100 pounds.
They are a challenge to pick up because the largest part to grab is the flywheel with its magnets and that turns. If you get your fingers pinched between the slowly rotating flywheel and the coil ring as the heavy beast swings when you pick it up, you yelp and drop it. It falls to the floor landing on one of your feet, breaking toes while the HCCT itself breaks. You hop around on one foot, trip over the now smashed HCCT and fall to the floor.
As I recall, when Ron Patterson would sell one, he would not ship it and required that you pick it up or make arrangements for some sort of "bucket brigade" to get it to you. I'm guessing that Joe is attempting to do this. So, can we help him out? I'm a bit out of the way.
- First Name: Joe
Bill is correct, I'm trying to arrange direct Pickup and transportation as the current owner will not ship. I haven't purchased it as yet, trying to resolve transportation prior to agreeing to purchase.
Thanks in advance
Thanks in advance
Regards,
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
They break down to more manageable parts pretty easily, and with much
less risk for damage when handling/shipping.
- MTFCA Number: 52564
I fully understand not wanting to ship. I did however did at one time suggest to remove the flywheel/magnets and coil ring to someone. They are off the shelf parts and I think some were sold that way.
1920 Dodge touring
1920 Dodge touring
Mr. Harper knows me all to well
Alright Bill ...,
Just can I did that the one time ...
Well - I guess twice ....
OK - but that third time ....
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- First Name: Joe
Thnx everyone, the Issue is resolved,
Mark,
Thanks for the idea of disassembling, the seller was able to remove the flywheel, coil ring and magnets, going to ship it in several boxes, the flywheel I have several on hand
Mark,
Regards,
- First Name: Ronald
- Last Name: Patterson
Joe
Be sure the AC Ammeter is removed and carefully packed in a high density Styrofoam padded box for shipping!!
The meter is the most costly part of a HCCT to replace if damaged and the easiest part to damage if not very carefully handled.
Ron Patterson
Ron Patterson
- First Name: Joe
Ron,
Thanks for your input, I passed it along to the seller
Regards,
Great! While you are waiting for it you could get the magnets charged and doctor up a coil ring.
1920 Dodge touring
1920 Dodge touring
