Advice Requested: Stewart Speedo Refurb
Posted: Fri Nov 22, 2019 2:00 am
I am looking for advice and guidance on refurbishing a Stewart speedo dial. As can be seen in the picture below, the dial has been affected by copper verdigris.
Can this be easily removed without also removing the black lettering? I have pondered using a mild acid like lemon juice or vinegar.
If cleaning does not work, is it possible to get a reprinted dial face? If so can you advise where or who can help with that?
How is the indicator arm removed? (so I can take the dial face out for cleaning without affecting the rest of the speedo).
I am intending to leave the speedo case as much as possible with the original patina, so cleaning the original dial is preferred to keep with that 'as found' look, just making the markings easier to read.
Many thanks
Adrian
Many thanks
Adrian
