Local Ford Agency Blank Check
Topic author - Posts: 61
- Last Name: Sundstrom
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Have a blank check from Ford Agency from town near me.
No Longer there but building remains. By the graphics from
the ‘23 to ‘25 era. Has anyone come across these type checks?
- First Name: Susanne
- Last Name: Rohner
- MTFCA Number: 464
Re: Local Ford Agency Blank Check
Nice find! I think I'd have to frame that one for the wall of the shop!
- First Name: Grady L
- Last Name: Puryear
Not exactly the same, but when I first started using or getting checks they were what were called "Counter Checks". You just basically filled one in with the name of your Bank and etc., the Merchants and all had these blank checks on their counters to use, hence the name. Hard to imagine how honest and trusting it was back then.
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- MTFCA Number: 49671
Great find!
I agree it should be matted and framed.
Congratulations,
Gene
Congratulations,
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
Thanks, framing is what I plan on doing with it.
Happy Thanksgiving to you all.
- First Name: Dennis
- Last Name: Seth
One thought on framing an item that has printing on both sides would be to use double glass. By that I mean is to build a frame with glass on both sides that way you can hang up the check and when it becomes a point of discussion you just have to lift it off the wall and show both sides without removing it from the frame.
Nice find by the way.
- Last Name: Shedrow
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring Car and 1926 Roadster
- MTFCA Number: 31023
- MTFCI Number: 23692
- Board Member Since: 2012
I found this set at a Model T swap meet a few years back. I have since seen some at other swap meets. A neat item for sure!
Scott S.
MTFCA and MTFCI member
1926 Ford Touring Car
1926 Ford Roadster
1926 Ford Roadster
- First Name: Gene
There are 4 of these checks on eBay right now for $4.99 Buy It Now plus $3.25 s/h.
It seems like a good deal to me.
Search- "Ford Agency Bank Check"
https://www.ebay.com/itm/Model-T-FordSo ... SwsnVd5ZXM
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
