Model t rear axle: Cad or detailed drawings
Posted: Mon Dec 02, 2019 11:55 pm
by Davey1916
Hey all, I'm after a cad file or someone that has sketched up a detailed drawing for the rear drive axles. The only thing I have close to either is the image i've attached which I found on here.
Many thanks for any help
Cam from DownUnder
Re: Model t rear axle: Cad or detailed drawings
Posted: Tue Dec 03, 2019 12:10 am
Posted: Tue Dec 03, 2019 1:34 am
by Davey1916
Thanks Steve unfortunately I'm after dimensions ect. But those drawings sure are cool!
Posted: Wed Dec 04, 2019 1:45 am
by Kevin Pharis
That drawing you have is pretty basic, and obviously lacks much needed tolerances. An interesting method of defining the taper across the entire length of the axle too... IIRC, it’s 3/4” per foot with centerline taper, can’t help you with gauge diameter, but know you need to keep pretty tight tolerance on the taper to maintain overall axle length
Posted: Wed Dec 04, 2019 1:22 pm
Just use the Ford Service book. You don't need drawings.
Posted: Wed Dec 04, 2019 3:19 pm
Here is a link with an additional picture for cutting the key way
http://www.mtfca.com/discus/messages/50 ... 1231423423
