Bosch DU4
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
MTFCA Number: 15143
Bosch DU4
Post by Plankhill » Tue Dec 03, 2019 4:41 pm
Has anyone run a DU 4 without an impulse coupling
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
MTFCA Number: 51354
Board Member Since: 2010
Re: Bosch DU4
Post by flatbroke3 » Tue Dec 03, 2019 6:28 pm
yes I have... we have 5 different cars with that mag and no impulse. 1912 Case, 1913 Case, 1911 Franklin and a '06 Franklin. I have also worked on a few early Buicks that are the same setup.
Harold.
FrankHarris
Last Name: Harris
* REQUIRED* Type and Year of Model Ts owned: 1913 Mountain Wagon
Re: Bosch DU4
Post by FrankHarris » Tue Dec 03, 2019 6:52 pm
1912 Buick been running for over 60 years that I know of. Do you need a du4 ?
Harry Lillo
First Name: Harry
Last Name: Lillo
MTFCA Number: 13996
Re: Bosch DU4
Post by Harry Lillo » Tue Dec 03, 2019 7:14 pm
I have a 13 T speedster with a Bosch DU4 side drive/ no impulse. No starter so you have to flip it fairly quickly to start.
With the Sherman Superfire head and Winfield carb it was a bit tougher to start.
I changed out to a stock (milled) 13 head and Holley carb for the 2008 Centennial. Much easier to start now.
If you were using a starter there should be lots of cranking speed to fire the plugs.
I am setting up another DU4 to run with my RAJO 4 valve.
In my opinion the Bosch magneto is the best Model T ignition system I have used.
Harry
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Bosch DU4
Post by Kevin Pharis » Wed Dec 04, 2019 1:23 am
Used to run a DU-4 on my ol’ 27 roadster with a Matco front plate without impulse coupling. Hand cranked the basically stock motor many times, and always started well.
Just a hunch... but I suspect many hard starting “ignition” issues are fuel related
Plankhill
First Name: Brendan
Last Name: Doughty
MTFCA Number: 15143
Re: Bosch DU4
Post by Plankhill » Wed Dec 04, 2019 6:43 am
Thanks for the input. I have a few of them and thought I would rebuild one and give it a try.
Shane Lach
First Name: Shane
Last Name: Lach
Re: Bosch DU4
Post by Shane Lach » Wed Dec 04, 2019 11:28 am
I run a ZR-4 on my speedster with a starter and 9:1 compression. No impulse and starts up great.
Dropacent
Last Name: Morsher
Re: Bosch DU4
Post by Dropacent » Wed Dec 04, 2019 12:08 pm
I run 2 cross drive front plates with a DU4 and no impulse. Never a problem. I love them ! I am doing another and going to use a “from the front seat” starting mechanism, and no starter motor so I am going to install an impulse, 1) because I have one 2) it may help just a bit. Keep in mind, most impulse couplings are left hand or right hand, and a very few can be switched easily and go either way. Another thing to get your mind wrapped around. Same with the mag itself, the side drive turns opposite of the front drive.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Re: Bosch DU4
Post by henryford2 » Wed Dec 04, 2019 12:14 pm
Starting a Rajo with a DU4 and no impulse coupler. https://youtu.be/5vgjgQQmHds
