sinking cork
Martin
First Name: Martin
Last Name: Cobb
sinking cork
Post by Martin » Sat Dec 07, 2019 7:39 pm
Not Model T but...my '49 Plymouth's gas gage cork float is sunk. Is there a modern replacement for cork floats?
MTFCA Number: 14972
MTFCI Number: 15411
Re: sinking cork
Post by RajoRacer » Sat Dec 07, 2019 7:47 pm
Lang's & Snyder's sell a modern composite float material which is alcohol resistant.
kmatt
First Name: Kevin
Last Name: Matthiesen
MTFCA Number: 11598
Re: sinking cork
Post by kmatt » Sat Dec 07, 2019 7:54 pm
Martin, If you can't get a float from a vintage MOPAR parts supplier, try contacting Langs T parts and see if they can get you a big enough portion of alcohol safe float foam to make your own float using the old one as a pattern. https://www.modeltford.com/model-t-part ... age-8.aspx
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: sinking cork
Post by CudaMan » Sat Dec 07, 2019 8:35 pm
If you decide to duplicate your old float in real cork, seal it with model airplane clear "hot fuel proof dope". Model airplane fuel is mostly methanol with some nitromethane and castor oil added.
Martin
First Name: Martin
Last Name: Cobb
Re: sinking cork
Post by Martin » Sat Dec 07, 2019 8:55 pm
Thank you all. I'll try the "slug" from Lang's.
Re: sinking cork
Post by Mark Gregush » Sun Dec 08, 2019 2:06 am
Before you order from Lang's, how big is it? The Model A modern type float might work. (same material as the blank from Lang's)
https://www.snydersantiqueauto.com/Prod ... /gas-gauge
I know the voices aren't real but damn they have some good ideas! :roll:
1921 Huckster
Gonenorth
First Name: Kevin
Last Name: Whelihan
MTFCA Number: 30688
Board Member Since: 2008
Re: sinking cork
Post by Gonenorth » Sun Dec 08, 2019 6:48 am
Got news for you...those black floats are made of a material called "nitrophyl" . Notice they are listed as "alcohol resistant", not alcohol proof. They too will absorb fuel and get heavy over a fairly short time. And it happens with non-oxygenated fuels as well. Had lots of trouble with them in various carbs that developed "heavy" floats and ran rich fuel/air mixes. About the only "cure" for that (and cork floats too) is to give them two or three coats of fuel-proof airplane dope. None of the cork or nitrophyl floats I have coated with that stuff have gone bad and absorbed fuel to date (about five years running) in various applications from outboards to snowmobiles and gas tank gauge floats. I still like the brass floats the best though. Just can't always find or adapt them for the applications I need.
Martin
First Name: Martin
Last Name: Cobb
Re: sinking cork
Post by Martin » Sun Dec 08, 2019 8:43 am
Thanks to 1922Ford for the personal reply, and to everyone else for your forum replies.
I have already ordered the float material from Lang's. I'll see how well it works.
The good news: it's very easy to access the sending unit on a '49 Plymouth, so no big deal if it sinks again.
