Obscure speedster trivia 2...?
Topic author - Posts: 1361
- Last Name: Pharis
Since the last go around was solved in just 30 minutes...
Anybody recognize this gear set?
- Last Name: Hughes
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
- MTFCA Number: 216
- MTFCI Number: 23070
Re: Obscure speedster trivia 2...?
Distributor gears.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Atwater Kent ??
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I agree with distributor gears, the lower one on camshaft and the other on the dizzy.
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Pharis
Getting warmer... but which one?
Not this one
- MTFCA Number: 52564
Delco? With all the different distributors made for the Model T this could be a real challenge. It's not Bosch.
1920 Dodge touring
1920 Dodge touring
- Last Name: Pharis
Not Delco... and it’s supposed to be a challenge!Mark Gregush wrote: ↑Sun Dec 08, 2019 2:39 amDelco? With all the different distributors made for the Model T this could be a real challenge. It's not Bosch.
While not Bosch either... this accessory did come outfitted with a Bosch distributor as an option...?
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
Probably drive gears for a triple plate.
Andy
Andy
Texas T distributor
1920 Dodge touring
1920 Dodge touring
- Last Name: Pharis
You got it!!
Here are a couple original Tri-Unit ads showing the timer elevator, and the Bosch option
- Last Name: Pharis
- First Name: Michael
- Last Name: Peternell
Now that is a !!! If you're into accessorie kind of things!
