Remove Hogshead
Topic author - Posts: 27
- First Name: Chuck
- Last Name: Lebeda
- * REQUIRED* Type and Year of Model Ts owned: 1919 Centerdoor
Remove Hogshead
Have a 1927 roadster. Can I replace the hogshead felt gasket without pulling the engine? Thanks, Chuck
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Remove Hogshead
I believe you can. But that big cast iron thing is pretty heavy. You want to use a lift.
- First Name: Chuck
- Last Name: Lebeda
Re: Remove Hogshead
Steve, thanks for the reply. I have done it several times with the engine pulled. There is not much room between the hogshead and engine. Just wondering how hard it would be to do a good job?
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Remove Hogshead
You can wrestle off that hogshead with both hands, but question is why?
Normally the felt seal over the block doesn't degrade. Unless someone left it off, and you have lots of oil streaming from the top of the hogshead.
The typical leaks at the hogshead are at the lower corners, where the hogshead joins the pan. There a bit of extra sealant is helpful, the Ford manual states to use a piece of candle wick, but good silicone sealant is useful too. Note the extra dab of black silicone on top of the fiber gasket that is sealed with Permantex. That felt gasket has been pre-soaked in varnish, that squeezes out and dries to a nice seal around the engine block curve.
Have fixed leaks at the lower side of the hogshead there, without pulling the hogshead, by cleaning very well all oil/dirt/grease at that corner on the outside, then wiped with lacquer thinner and get those outside lower corners very clean. Then apply a large dab of black silicone sealant on the outside at the lower corners, that will stop oil seeps.
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Re: Remove Hogshead
Hard.
I’d rather have someone beat me with a stick.
Ask me how I know.
1924 Touring
- First Name: Don
- Last Name: Allen
Re: Remove Hogshead
Hey Don A ! So, who has been beating you with a stick?
- First Name: Chuck
- Last Name: Lebeda
Re: Remove Hogshead
Rusty Ford: That's what I thought!! Thanks
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Remove Hogshead
He has a ‘27 roadster... That’s probably one of the easiest ones to pull the hogshead on. There is plenty of access thru both front doors. Even better access if you remove the door hinge pins and take the doors off.
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
Re: Remove Hogshead
Can be done...but sort of depends on age and agility...lol...ask me how I know!
I was able to get a hogshead 'up' without pulling things apart, lots of wiggle-wiggle with a putty knife around the flanges and edges...did have to also pull the exhaust manifold tho' after wasting time looking for 'just right' while lifting...it was THAT close!
I went more or less straight up and then turned 90 degrees while standing on the running board to get the hogshead out of the car. Knee went 'pop' and I was determined to not drop the hogshead. Oh well, so that's what those knee braces are for when you cross the magic age line...lol.
No problem tho' that now squirrelly knee 'got fixed' on a later T adventure. Looking at parts in the loft for a question on this site and then waking up 3 days later in ICU. My leg in an immobilizer that lasted 6 months more and being told the shattered kneecap from the fall had pieces too small too pin...so...a 7 hour surgery to find what was over 50 shattered pieces and super-glue them back together. 2 years of therapy later I can walk again...still can't get under the T but thats OK (Suncoast T membership comes with volunteers and advisors...lol). Now there is no rotation at all in that knee, never will be as all the ligaments are trussed up with titanium bridge wires that pull on the quads and shins like a caught fishhook if I try something out of the expected.
Not complaining, the alternative was whole lot's worse, right? But...be careful out there as to this day I am NOT sure my in car removal and that 'pop' did not maybe influence my later 'miss'. Gosh...I love T's.
BE CAREFUL OUT THERE...
- First Name: Chuck
- Last Name: Lebeda
Re: Remove Hogshead
Thanks for all the info. My mechanic friend was going to replace this gasket for a different owner. He may just suggest Dan's technique and see what he wants to do.
Re: Remove Hogshead
I, too, agree with Dan's comments and will add my opinion/clarification to his message: The black silicone sealant to use is Ultra Black Gasket Maker RTV. This is far FAR superior to other springy/stretchy products on the market. They have a purpose and use in life; just not this one.
NH Full Flow Float Valves
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
- MTFCA Number: 30697
Re: Remove Hogshead
I am sure back in the day a mechanic would be fired if they couldn't do it:) But I would say that it is some work.
I have removed and replaced the hogshead on a couple of engines. The two most recent I had the leak between the felt seal and the pan. Good to see that I am not the only one:) Also a good reminder to put silicon there BEFORE putting it back together. I did the clean/and try to get silicon method after the fact now it doesn't leak too much.
Matt
Matt
- First Name: Harold
- Last Name: Schwendeman
- MTFCA Number: 0
Re: Remove Hogshead
Scott Conger - Not trying to be some kind of "know-it-all" butt-head PITA, but I agree with you completely and would add just one word to your clarification suggestion of Ultra Black Gasket Maker RTV, and that is that it will be found on most auto parts store shelves in a group of "Permatex" products because it is in fact a "Permatex" product,....FWIW,.....harold
- First Name: Don
- Last Name: Allen
Re: Remove Hogshead
wayne sheldon wrote: ↑Sun Dec 08, 2019 5:19 pmHey Don A ! So, who has been beating you with a stick?
1924 Touring
- First Name: Clyde
- Last Name: Gibson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
- MTFCA Number: 32266
Re: Remove Hogshead
I found for myself it is easier for me to,pull the motor. I can can get the hogsheads off all right but not back on easy. Have a good day. Clyde
- First Name: Don
- Last Name: Allen
Re: Remove Hogshead
In all seriousness, it’s all about the weight of the @#*! thing and access.
Using an engine hoist would help with the weight. Access in my 24 Touring is poor at best. I can see how a 26/27 open car would be better.
1924 Touring
- First Name: Michael
- Last Name: Pawelek
Re: Remove Hogshead
In the past I have lifted the hogs head in different areas just enough to slide in tiny wooden wedges, apply the gasket sealant, then pull the wedges out and bolt back up.
