Coil tester
Posted: Tue Jan 29, 2019 4:23 pm
by Model t tommy
does anyone have any information on this tester
Re: Coil tester
Posted: Tue Jan 29, 2019 7:42 pm
by BE_ZERO_BE
This is a Ford 17-Z-803 Tester.
It is the predecessor to the 18-Z-245 Coil Tester.
Re: Coil tester
Posted: Tue Jan 29, 2019 8:07 pm
by Ruxstel24
I knew Bob would know. :)
Re: Coil tester
Posted: Tue Jan 29, 2019 8:53 pm
by Model t tommy
Thanks for the info. As always Tom
Re: Coil tester
Posted: Tue Jan 29, 2019 9:55 pm
by BE_ZERO_BE
I learned what I know about HCCTs from Ron Paterson :D
Re: Coil tester
Posted: Fri Feb 01, 2019 11:03 am
I don't know how a Model T owner can be without one. I use mine frequently for myself and others.
Re: Coil tester
Posted: Fri Feb 01, 2019 11:39 am
by Tom Hicks
The HCCT works well, but it is not the only girl in town. I have found the ECCT to be very accurate, and probably lower in cost.
Re: Coil tester
Posted: Fri Feb 01, 2019 11:50 am
...and probably lower in cost
The ECCT is about half the usual cost of the HCCT, and so is the Strobo Spark.
Re: Coil tester
Posted: Fri Feb 01, 2019 12:19 pm
by Ruxstel24
Along with my Allen HCCT, I have several different ECCTs, both 6V and 110V AC...
I prefer the HCCT, but run a distributor, so it rarely gets used.
Re: Coil tester
Posted: Sat Feb 02, 2019 12:42 pm
by Ruxstel24
Here's a couple ECCTs, one DC and one is AC.
Sorry bout the glare, sunshine ! 8-)
There's a homemade one that holds 4 coils, but the picture didn't come out.
Re: Coil tester
Posted: Sat Feb 02, 2019 12:48 pm
by BE_ZERO_BE
Here are some interesting things that I discovered about the Jefferson Model 28 Coil Tester.
viewtopic.php?f=2&t=269&p=1586&hilit=jefferson#p1586
Re: Coil tester
Posted: Sat Feb 02, 2019 12:49 pm
by Ruxstel24
And my Allen tester :)
Re: Coil tester
Posted: Sat Feb 02, 2019 12:51 pm
by Ruxstel24
Appears to be the one on the wall is a Jefferson.
Thanks Bob ;)
Re: Coil tester
Posted: Sat Feb 02, 2019 5:02 pm
by HalSched
I gave one of the Jefferson #28 testors to the Museum. I hope they still have it
Re: Coil tester
Posted: Sat Feb 02, 2019 8:09 pm
by Doug Keppler
Dave, with all due respect I believe the ECCT is the Electronic Cranked Coil Tester as designed and sold by Mike Kosser www.modeltecct.com
Re: Coil tester
Posted: Sat Feb 02, 2019 8:35 pm
by Ruxstel24
Pardon my ignorance, what should I call a non hand cranked tester.
No offense to Mike was intended. :)
Re: Coil tester
Posted: Sat Feb 02, 2019 10:20 pm
by Doug Keppler
It's probably a buzz box coil tester which most likely only tests the primary and secondary coils to tell you if they are good
